Question about Whirlpool WED9500T Electric Dryer
Whirlpool duet dryer stuck on steam cycle
While operating in the normal cycle, my dryer sprayed water onto the clothes to the point where there was standing water in the dryer drum that leaked onto the floor. After cleaning up the mess, we were delighted to find that the dryer still worked and had not shorted out. In an effort to troubleshoot the problem, we started and stopped the dryer and switched between cycles to see if the water continued to spray in every cycle. Indeed, it sprayed no matter the cycle, but then, at one point stopped spraying after one of the mode changes we made. Now the steam mode does not work at all. I can live without the steam mode, but I am afraid that the water will randomly come on again during a non-steam mode. This issued happened once before but I caught it before the drum got flooded. Any ideas on what may be causing this?
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
One trick to stop the steam is to remove the water hose connected to the dryer
Posted on Nov 22, 2013
Testimonial: "Indeed, that would stop the issue of the water coming on randomly, but I would prefer to fix the problem and have a fully functioning dryer."
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
  • 32 Answers
SOURCE: whirlpool lgn2000jqo gas dryer won't stay lit
the flame sencer window my need cleaning
Posted on Oct 20, 2009
SOURCE: Our whirlpool dryer has started to rust on top.
Did you receive any suggestions for this? My husband just brought home a used Whirlpool dryer that has this rust on top also.
Posted on Feb 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Steam Dryer Beeping
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$%^
Posted on Sep 30, 2010
jnchahn
  • 252 Answers
SOURCE: my brand new (2 weeks) Duet dryer seems to be
If it is brand new. It should have full factory warranty. I would called the place that you bought it from and have them fix it.
Posted on May 07, 2011
My Whirlpool Duet DRYER--the clothes are wetter than when I put them in & there is now water sitting in the bottom. It does have a steam setting, but I'm not using that one. It's 4 years old.
Check your exhaust vent! If you have an obstruction, the steamy air will have no where to go, then your air-conditioning temps inside can cause the water to condense in the vent tube... Even if the vent is just open to the hot summer air and the clothes sit in the machine the difference in temps between inside and outside can cause these symptoms...
Jul 25, 2016 | Whirlpool Duet High Efficiency Gas Dryer...
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Duet steam dryer soaking my clothes
You will need to replace the "water valve" on the unit. The solenoid is letting to much water thru. Here is a link to the part to order.
Nov 04, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
My whirlpool duet steam dryer appears to be stuck on the steam cycle. I put in a load of clothes that were barely wet and now they are soaking wet. The heating element is working but they are still...
Hello, Thank You for using FixYa. I will be helping you today.It can be a stuck relay to the water valve or a water valve that is not closing all the way. Put a towel across the bottom of the drum a few hours and see if it gets wet when the unit is not in use if so the valve is stuck open and needs to be replaced.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Dryers
Duet steam dryer soaked clothes and had alot of water setting in drumclothes were dry and wrinkled when i put them in the dryer 5 minutes later they were soaked.
Turn off the water or disconnect the water hose to your dryer.
Call your serviceman and tell him to order a new water solonoid for your dryer.
You can dry without the water hooked up to the dryer.
The steam cycles, however, will not have steam due to the absence of water.
Mar 23, 2011 | Whirlpool Duet Steam WFW9700V Front Load...
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool WED9500T Electric Dryer Logo
357 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
