Question about Garden
Hard starting toyota crown petrol engien - Garden
My car is let to responding when to start(hard starter).when engine is hor Toyota 2uz fe 200 seres
if diesel glow plugs
if petrol ..old battery or lazy starter fuel pump issue
Oct 12, 2016 | Toyota Cars & Trucks
Start engine
tune up replace filter both air and petrol cant do anything for a worn engine but rebuild it or replace LOL
Aug 19, 2014 | 2007 Toyota Quantum 2.5
2001 model with hard start,what can i check
if a petrol engine then check the spark plug gaps ,should be 25th this is the main cause of a hard to start engine
Aug 12, 2013 | Toyota Hilux Cars & Trucks
When i try to start the car the engiene tries to start but its like the petrol is not going through? Therefore the car did not start!!
No initial combustion (engine does not start)
1. ECM power source circuit
2. Crankshaft position sensor
3. Camshaft position sensor
4. Ignition system
5. Fuel pump control circuit
6. ECM
7. Voltage output circuit
Engine cranks normally but difficult to start
1. Fuel pump control circuit
2. Compression
Dec 08, 2012 | 2005 Toyota Yaris 1.3
I put desel wrong petrol in my toyota corolla .what to do and how much will be the cost
just siphon it out and fill with gas it might be hard to start at first but it will be ok
Mar 29, 2010 | 2000 Toyota Camry
Toyota 3y engine fuel system
LPG 3Y engine toyota crown comfort automatic - fuel consupmtion is 13.30litre per 100km? How can this be reduced?
Jan 08, 2010 | 2002 Toyota Camry
When i start in the morning,the engine won't idle and when i drive,gear change is very,very slow.wen it warms up its OK, I have a 1996 toyota royal crown with a 3l, six cly inline, petrol engine
Change a sensor for fuel mixture preparation.Also colled ECT /engine coolant temperature/sensor.There is two sensors-one is for fuel gauge on an instrument panel-change another.
Dec 08, 2009 | 1996 Toyota Avalon
Can't start my car
The starter is located partially underneath the engeine in the center rear , right about at the midpoint of the cylanders anout 6- 12 down , its mostly hidden be the engiene itself, but you can see it by leaning over the engiene and peering down the opening, an easier way would be looking at the cap for your oil going right about 6 inches and looking down, another problem I've had with my corolla which i thought was the starter ended up being the erosion of the terimnals on the battery cables, the positive terminal is attached to a fusebox, connect by a small terminal, which can erode, you can fix that issue by rigging the battery with a piece of metal to conduct and a replament terminal on the battery.
Feb 20, 2009 | 1991 Toyota Corolla
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
