Question about Yamaha Music
Static crackling sounds
My Yamaha Clavinova CLP-411 has been perfect the 14 years I've owned it. In the past few weeks it has developed a cracking/static noise coming from the speaker. It sounds like the noise you hear when a microphone cracks real loud, although sometimes less loud. I don't want to invest a lot of money in repairs, but not sure what to do. I may consider buying a newer model.
  • 21 Answers
Replace the speakers or let it be repaired by some one.their may be rust near the speaker coils.just giv it a try.
Posted on Nov 22, 2013
  • 4 Answers
SOURCE: Repair a Mackie SRM 450 Speaker
You probably need to replace the diaphragm. The diaphragm is located behind the back cap. Simply remove the back cap, remove the diaphragm, clean the voice coil gap with a piece of masking tape, install a new replacement diaphragm, reinstall the back cap. That it!
You can see videos on how to replace diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-c/INST/Installation+Instructions
You can buy a new Mackie SRM450 diaphragm at this link.
http://www.soundspeakerrepair.com/speaker-parts-cp/SRM450-DIA/DIA-Mackie/Mackie/
Posted on Jul 21, 2009
SOURCE: keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Posted on Aug 14, 2009
  • 5603 Answers
SOURCE: Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Posted on Nov 18, 2009
SOURCE: bp's problem. I have a CLP-110, Yamaha
call up Yamaha. They will fix it for free as it is a manufacturing fault.
Posted on Feb 28, 2010
Testimonial: "Thank you very much for that timely information. I'll call Yamaha today and see how they want to proceed. Thanks again."
  • 2468 Answers
SOURCE: I own a Peavey XR696F
check any and all filter,cross-over,and de-coupling capacitors in every circuit especially on the left channel side,but check all capacitors anyway on both channels,as one channel can affect both left and right channels, also a capacitor can heal itself over time and do the same thing again later,"Cold-Solder" joints can do this also, on a printed-circuit board, HINT:heat and cold can cause problems so,try heating, joints,caps,etc. or buy a can of freeze mist(to cool components) at an electronic parts store and gently heat or cool each suspect component waiting for the outcome,or wait till the condition starts and then try the cooling,because the component has already been thermally warmed up by the circuitry power
Posted on Jan 31, 2011
No sound on my Yamaha Clavinova CLP-311
Try these steps:
  • Perhaps inadvertently, there is a MIDI settings are changed.
    Setting LOCAL-ON must be in the ON position.
    Do this (see Figure 1):
  • Connect AUX OUT (at rear panel) to an external amplifier. If the sound is heard, the damage was CLP311 power-amp.25893993-xykdzr1cdriwl1tmr4ngy0qt-3-1.jpg
Oct 05, 2015 | Yamaha Music
Does a Yamaha clavinova clp 760 have a fuse that may need changing
There are a number of fuses on the main power board ( by transformer ) the sizes differ depending on the country of use but are clearly marked on the board.
REMEMBER TO UNPLUG FROM THE MAINS BEFORE OPENING - if in doubt seek the advice of a qualified electrician
Mar 07, 2015 | Yamaha Music
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
I have a Yamaha Clavinova CLP-50 Digital Electric Piano serial number 19071 and would like to find its age. Many thanks Phil
If you will turn the instrument upside down you will find a date of production somewhere. My CLP-50 has been built in 1985 for example, I discovered in 2006. (I have forgotten the exact location of this date.)
Jan 03, 2010 | Yamaha Music
Nov 17, 2009 | Yamaha Music
Yamaha clavinova clp 200 - ear phone jack slid
The control panel hinges upwards and you have to move the keybed back a bit to get at the jack. All the screws on the bottom for the keybed. I'm not sure where the ones for the control panel are.
Oct 12, 2009 | Yamaha Music
Keys stick on Clavinova CLP 360
Jan 19, 2009 | Yamaha Full-Size Keyboard
Yamaha Clavinova CLP 260
hi...
Your L/R jacks in the back need to connect to the "line-in" connector on your sound card.
I think the jacks on the Clav are 1/4 inch. Go to Radio shack and ask for an adapter that will take two 1/4 inch plugs/cable and convert it to a 1/8 inch stereo plug.
The Midi connects From (keyboard) To (soundcard)
Cables are available at any music store
Jan 12, 2009 | Yamaha Full-Size Keyboard
Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
Jan 04, 2009 | Yamaha Full-Size Keyboard
Music Logo
605 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
