Copies come out blank
Copies came out with black smudges down page. I opened the printer and cleaned it Now I get nothing printed when I copy
    Problem Solver:
  • 21 Answers
You need to clean it more.and try to re-install the driver
Posted on Nov 21, 2013
4 Suggested Answers
SOURCE: A960 printer
I HAVE A DELL A960 PRINTER AND I REPLACED NEW BLACK CARTRIDGE BUT I KEEP GETTING THE MESSAGE " CARTRIDGE ERROR 50 ".
I DISCONNECTED AND RECONNECTED THE POWER BUT NO LUCK.
DO I NEED TO REPLACE THE COLOR CARTRIDGE TOO, SINCE IT IS EMPTY.
PLEASE ADVISE.
THANKS.
Posted on Sep 19, 2008
checkitright
  • 1362 Answers
SOURCE: Canon PC-6re copies are all black
1-the scanning lamp is not coming on
2-seperation is not working properly
3-the HVT for the seperation is not working
Posted on Oct 08, 2008
SOURCE: I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Posted on Sep 03, 2009
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
Dirty copies on Canon PC1060
First replace drum cartridge
Nov 04, 2009 | Canon PC1061 Copier
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Epson cx3810 printing blank copies
I had the same problem and had to clean the nozzle tubes. After cleaning the tubes, printer worked great again.
Hope this helps.
Charlene
Mar 11, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Multiple page printing
if it's one original making 20 copies and doing the problem then you have a problem with the
a) Primary
b) Seperation unit
I would change the Sep 1st
Sep 08, 2008 | Canon PC-940 Black and White Copier
Black mark on printed copies
Remove the black drum and see if see the line on the drum that you see on the paper---if it is replace the drum unit.. Good Luck
Aug 26, 2008 | Ricoh CL4000DN Laser Printer
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
jasbo
jasbo
