Question about Gateway GT5220 PC Desktop
Will turn on with test switch but not with the on off switch
    Problem Solver:
  • 10 Answers
Just wondering have you knoked away wires inside computer
Posted on Nov 20, 2013
2007 Ford Explorer flasher relay
There is no flasher relay , all done electronically by the smart junction box (computer )
The smart junction box (SJB) monitors the multifunction switch position by sending multiple voltage reference signals to the multifunction switch. When the multifunction switch is in the LH or RH TURN positions, or the hazard lamp switch is engaged, that input signal is routed to ground.
When the SJB receives an input from the multifunction switch indicating a request for a turn signal or hazard lamps, the SJB then supplies voltage to the appropriate turn lamps.
Your best bet would be to take it to a qualified repair shop or dealer .
Do you know what DTC'S are ?
Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Chart DTC Description Action B1499 Lamp Turn Signal Left Circuit Failure Go To Pinpoint Test M . B1502 Lamp Turn Signal Left Circuit Short to Ground Go To Pinpoint Test M . B1503 Lamp Turn Signal Right Circuit Failure Go To Pinpoint Test M . B1506 Lamp Turn Signal Right Circuit Short to Ground Go To Pinpoint Test M . B2048 Left Rear Turn Lamp Circuit Short to Ground For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2049 Left Rear Turn Lamp Circuit Open For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2050 Right Rear Turn Lamp Circuit Short to Ground For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2051 Right Rear Turn Lamp Circuit Open For Mountaineer, Go To Pinpoint Test M .
For Explorer or Explorer Sport Trac, REFER to Stoplamps in this section. B2071 Hazard Switch Signal Short to Ground If the hazard lamps are inoperative, Go To Pinpoint Test N .
If the hazard lamps are always on, Go To Pinpoint Test O . B2281 Right Turn Switch Short to Ground Go To Pinpoint Test L . B2282 Left Turn Switch Short to Ground Go To Pinpoint Test L . All other DTCs - REFER to Section 419-10 .
Apr 22, 2017 | Ford Cars & Trucks
No turning signals
Turn Signal Lamps
The turn signal lamps are made up of the front park/turn signal lamps and rear turn signal lamps. The front turn signal lamps flash with the rear turn signal lamps when a turn is initiated using the turn signal/multifunction lever. The turn signals will operate only with the ignition switch in the RUN position and will not operate during hazard flasher operation.
When the ignition is turned to the RUN position, battery voltage is supplied to the TURN SIGNAL, CORN LPS Fuse. Battery voltage is then applied through the TURN SIGNAL, CORN LPS fuse circuit to the hazard warning switch. The hazard switch supplies a turn signal flasher signal to the turn signal switch. With the turn signal switch in the LH or RH position the corresponding turn signal indicator, rear turn signal, and front turn signal receive the turn signal switch signal and will flash. The front turn signals receive the turn signal switch signal from the turn signal switch via the body control module (BCM) . The front turn lamps are grounded at G101. The rear turn lamps are grounded at G301 and G302.
Turn Signal Lamps and/or Indicators Inoperative
  1. Turn the ignition switch to the ON position.
  2. Place the turn signal switch in the LH and RH on position.
Do the turn signals operate properly?
Go to Testing for Intermittent Conditions and Poor Connections yes
Go to Step 3 no
Are all of the turn signal lamps and indicators inoperative?
Go to Step 5 yes
Go to Step 4 no
Are only the turn signal indicators inoperative?
Go to Step 16 yes
Go to Step 9 no
5
Check the TURN SIGNALS CORN LPS fuse for an open.
Is the TURN SIGNALS CORN LPS fuse open?
Go to Step 25 yes
Go to Step 6 no
6
  1. Disconnect the hazard switch.
  2. Turn the ignition to the ON position, with the engine OFF.
  3. Connect a test lamp between the ignition positive 1 voltage circuit of the hazard switch and a good ground.
Does the test lamp illuminate?
Go to Step 7 yes
Go to Step 27 no
7
Connect a test lamp between the ignition 1 positive supply voltage circuit of the hazard switch and the ground circuit of the hazard switch .
Go to Step 8 yes
Go to Step 23 no
8
  1. Install a fused jumper between the ignition 1 positive voltage circuit of the hazard switch and the turn signal flasher signal circuit of the hazard switch.
  2. Place the turn signal switch in the RH on position and the LH on position.
Do the turn signal lamps illuminate?
Go to Step 17 yes
Go to Step 15 no
9
Is a front turn signal inoperative?
Go to Step 10 yes
Go to Step 13 no
10
  2. Disconnect the inoperative front turn signal lamp.
  3. Connect a test lamp between the supply voltage circuit of the inoperative front turn signal lamp and a good ground.
  4. Place the turn signal switch in the appropriate ON position.
Does the test lamp flash ON and OFF?
Go to Step 14 yes
Go to Step 11 no
11
  1. Disconnect the body control module (BCM) connector.
  2. Connect a test lamp between ground and the front turn signal switch signal circuit of the BCM.
  3. Place the turn signal switch in the appropriate ON position.
Go to Step 12
Go to Step 22
12
Test for an open or for a high resistance in the supply voltage circuit of the inoperative front turn signal lamp. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step 34
Go to Step 21
13
  2. Disconnect the inoperative rear turn signal lamp.
  3. Connect a test lamp between the supply voltage circuit of the inoperative turn signal lamp and a good ground.
Go to Step 14
Go to Step 28
14
Connect a test lamp between the ground circuit of the inoperative turn signal lamp and supply voltage circuit of the inoperative turn signal lamp.
Go to Step 20
Go to Step 26
15
Test for an open or high resistance in the turn signal flasher signal circuit. Refer to Circuit Testing and Wiring Repairs .
Go to Step 34
Go to Step 18
16
  1. Turn OFF the ignition.
  2. Disconnect the instrument panel cluster (IPC).
  3. Connect a test lamp between the supply voltage circuit of the inoperative turn signal indicator and the instrument panel cluster (IPC) ground circuit.
Go to Step 19
Go to Step 24
17
Inspect for poor connections at the harness connector of the hazard switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 30
18
Inspect for poor connections at the turn signal switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 29
19
Inspect for poor connections at the instrument panel cluster (IPC). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 31
20
Inspect for poor connections at the inoperative turn signal lamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 34
Go to Step 32
Sep 05, 2015 | 2001 Oldsmobile Intrigue
Signal lights nor turn signals work. new bulbs an flasher switch
It could be the turn signal switch. Test to see if current is getting to the turn signal switch and if it is then test to see if current is getting from the turn signal switch to the flasher.
May 26, 2015 | Cadillac DeVille Cars & Trucks
Windows cannot go up or down
If fuses and relays are good or new, your gonna have to check the window motor and switch next. You'll have to remove the door panel for this and a test light as well which can be found at your local auto parts. Once the door panel is off, leave the window switch plugged in. Connect your alligator clip on the test light to a ground source. Then find the 2 wires that go to the window motor. Make sure your ignition switch is on and stick the tip of the test light into one of the wires that go to the motor and try the window switch. If the test light turns on, stick into the other wire too. If the test light turns on when the switch is hit, you have a bad window motor. If the test light doesn't turn on when you try the switch for either wire, you may have a bad window switch or your main window switch at the driver seat (master switch) is bad. Hope this helps you out. Good luck.
Mar 15, 2015 | 2006 Ford Taurus
My garbage disposal isn't working. it doesn't even make a sound when i hit the switch. i checked the circuit breaker and it's not that...i pushed the reset button underneath and it didn't help, either.
On the bottom of the disposal there is a small red reset switch. Push it in and see if it stays. Turn on switch and see what happens. If it hums or buzzes take a 1/4 inch allen wrench and insert it into opening in the center of the bottom. Turn wrench back and forth while running hot water through disposal to help clear any blockage. Turn on switch on and see if thats helped. Thank you.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I cant get both switches to work properly one minute it turns the light on the next they done work. is the red wire suppose to hook up to the black screw
The key to three-way switches is the dark screw.
And different brands of switches put dark screw on different side of switch.
So, lets get out of this mess with a bit of testing.
You have two switches with 3 wires on each switch for a total of 6 wires.
Take out both switches and separate wires for testing.
Turn on power and test each wire to bare copper wire.
One and only one wire will test Hot.
The hot wire goes to dark screw on switch1.
The other two wires in that box go to either screw on switch1.
One switch done, one switch to go.
Move switch1 lever to down position.
Turn on power and test 3 remaining wires.
One wire will test hot. Mark this wire.
Move switch1 to up position, and test 3 remaining wires again.
A second wire will test hot. Mark this wire.
The 2 marked wires attach to either brass screw on switch2.
The third wire attaches to dark screw.
Both switches done.
Nov 19, 2010 | Pass & Seymour Trademaster 3-Way 15 Amp...
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Jul 19, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Signal switch testing
Switch on you 4 way/emergency flasher, if all indicators work with that but not your turn switch, its a turn switch problem.
Mar 29, 2010 | 1995 Toyota Corolla
Wont turn or spin
  • Hi,
  • Try these:
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
please rate my suggestion...
May 19, 2009 | Indesit W 123 Front Load Washer
Gateway GT5220 PC Desktop Logo
18 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
