Question about Worx Garden
Something stuck in blower - Worx Garden
My heater blower motor burned up. Why? I have a 1992 Oldsmobile cutlass ciera s.
Difficult to say from here.
Could have been old age, a weak connection, something got stuck in the blower wheel, or something else.
Oct 12, 2015 | Oldsmobile Cars & Trucks
I have 2001 E350 van heat gets hot blower works but doesn't blow out vents what's wrong
Could be a stuck blend door under the dash, something blocking the passage, or the blower motor wheel is not attached to the blower motor.
Jan 05, 2014 | Cars & Trucks
Why is my Husqvarna 125bt Backpk Blower beeping?
There are no warning buzzers or electronics on the unit. You need to look for something that may be making the noise... A loose motor mount behind the impeller, something stuck inside the shroud that the impeller blades are scraping, a loose cylinder or spark plug causing a compression leak are somethings that I can think of that may cause a beeping or squeeking sound. Maybe a partially clogged exhaust.
Nov 09, 2012 | Husqvarna 125bt 25.4cc 2-stroke Gas Backpk...
Weed eater fb25 won't start
This blower is fuel sensitive! Gas and oil mixture has to be correct. Too much oil will cause carbon buildup in the cylinder. In my case my blower would not start after several uses this season. I checked EVERYTHING....spark, fuel delivery, air filter.....then checked the flywheel which has no separate key....the key is cast into the flywheel. Read somewhere about the carbon buildup so took the cylinder off and viola! The piston ring was firmly stuck in the piston groove plus the cylinder was carbon scored. I tried to gently pry the piston ring free but it was so firmly stuck, it broke. Not worth fixing. Take the muffler off and you will be able to see the piston ring....use a small pick or something to see if the ring is free. If not, proceed to tear down or throw out. I was able to see scoring on the piston and determine my ring was stuck this way. Remember the elements needed for successful ignition...fuel/air...spark....compression. Stuck ring = low compression. The last time you ran the blower the ring became stuck...the engine continued to run because of the engine rpm's but when you try to start at low RPM's, no luck.
Jan 18, 2012 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
The motor hums but if i take off the tension spring the motor spins fine
if you mean you disconnected the belt and the motor spins you could have something stuck in the blower wheel like a sock or something,you might have had the filter out and ran the dryer and something went down into the blower wheel,also the motor still could be bad not strong enough to spin drum
Nov 02, 2009 | Maytag Dryers
Vibration in blower fan
you will have to take the blower motor out.
there is either something in the cage or the cage has a small break in it
Jul 10, 2009 | 2003 Dodge Stratus
My dryer does not start.. when I push the start button all it does is hummmm... kind of like the motor is stuck or jammed. It did work last nite and this morning so I don't know... is it something...
Hi
Check for something jammed in the fan blower, worn glides or rear bearing jamming the drum, but unfortunately 9 times out of 10 this is a bad motor and you will need a new one.
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
Jul 05, 2009 | Maytag Dryers
Amana Dryer
sounds like a bad motor or something stuck in blower fan.. see if you can maually turn the drier drum if so motor is bad if not something is binding up drum or blower fan.
Nov 03, 2007 | Amana DLE330RAW Electric Dryer
Garden Logo
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
