Question about Ricoh Aficio 1027 All-In-One Laser Printer
Aficio 1027 only print first couple of pages
Printer working 100%, except when we printing from the PC it only print the first couple of pages. Reduced the buffer settings to minimum that seems to help a bit with this problem. Any idea what can cause this - using parallel printer cable.
  • 48 Answers
Could be several things. I would start by eliminating the easiest things. Try another cable, decrease dpi settings (less memory usage), try a USB cable to see if theres a difference if a port is available. Update the print driver from Ricoh website.
Posted on Nov 23, 2013
4 Suggested Answers
drichards
  • 87 Answers
SOURCE: Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
Posted on Feb 26, 2008
  • 22 Answers
SOURCE: Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Posted on Aug 09, 2009
SOURCE: ricoh aficio mp 1600 L printer driver has been
E000002-0000 le code panne ci dessous
Posted on May 28, 2010
My new ricoh aficio sp 100su ddst printer has hardly printed 100 pages and now it show E7 and doesn't print. what must I do?
Go to page setting option and set page range and page auto print. If printer ok then may be E7 browser not full support so that up to date then you try.
Read More Help... Ricoh SP 100 Printer Need to press Form Feed button every time to print... and Ricoh Printer Support
Thanks,
Sep 10, 2014 | Office Equipment & Supplies
Only printing coding
sounds like you have the wrong print driver for the mfp
Jan 08, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
Afico 1027 Printer not printing all the pages
I haven't seen such problem in this printer
Anyhow uninstall the printer software and reinstall it
You might have PCL6 driver
Try RPCS Driver from Ricoh Web
Nov 20, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
I can not get my Aficio 1027 to print or scan from any computer. PLEASE HELP!!
You should have to install pallet tray application or software for it. when you install the Driver of your printer at that time install it your driver on custom and select the PALLET TRAY and install it. or you may install it separately from your Driver CD.
George Bush...
Aug 25, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
How to print middle page from scanned document
Dear! First of all, You should check your printer timer may be it enable and after the completing the time it shutdown automatically. Secondly, You choose custom option and use it command it from 85 to 100 and 30 copies for each it will work completely.
Thank You
Jul 25, 2009 | Ricoh Aficio AP410N Laser Printer
Ricoh printer prints nonstop when plugged up& is in code
clear you print files in your print  que
http://www.websitetoolbox.com/mb/copierquestions
Jan 15, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 will not print multiple pages or multiple documents. Once restarted it will print the files. But then does it again once you try to print files again and you have to restart it. Worked...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
White vertical lines on printed page
change the k black drum... its the only solution trust me
thanks
Nov 19, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1027
There are two possible options:
Printer Module (B461)
This requires the 64MB memory option (G579).
Printer/Scanner module
This requires the 64MB memory option (G579) and the NIB (G574).
Good luck and please rate me, thanks.
Nov 04, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
35 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
