Problem with Printers & Copiers Minolta di551 error 29-04
3 Suggested Answers
goalie39
  • 469 Answers
SOURCE: error code c0200 minolta ep4050
C0200, charge corona failure.
The high voltage wire used to charge the photo-conductive drum is broken or shorted.
It will need to be repaired or replaced.
It is usually a fairly simple job, but you may need the replacement wires to complete the job.
It could be someone has pressed the scoritron grid tensioner and allowed the grid to drop onto the drum.
Great care must be taken when working around the drum area.
If you open the front of the machine.
drop down the transfer section (yellow or green handle)
flip out the toner bottle.
you should see to recessed screws, one behind the toner bottle, one on the far right side of the unit. loosen these all the way,
there may be a plug in each side to disconnect.
you should now be able to slide the unit out.
set it down in some paper, the corona will be the long metal housing stretching front to back on the drum unit.
Remove it by sliding it one way, then it should open like a hinge, open it all the way and it should pop loose of the main unit.
The corona wire is behind the grid, it is the thickness of a human hair. If it is broken you will need a replacement, if the grid was off when you opened the unit up reinstall the grid and reassemble.
If the corona shell or the scoritron is discolored, clean them with a glass cleaner and soft cloth.
Keep the drum covered with paper so it is not exposed to direct light for any great length of time, do not allow the drum to be exposed to direct sunlight.
Hope this is of some help.
Ed
Posted on Apr 19, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Service Call error C0F32 in Konica minolta copiers
Since you did not include the Model number I will suggest the following:
This code means pretty much the same on all Konica/Minolta machines.
The ATDC or automatic toner density control has experianced a problem. Have you run the copier out of toner by chance?
You can try resetting this code to see if it comes back. If it keeps coming back then you are going to need the process unit serviced. Or depending on the model you can replace the "Imaging Unit" yourself.
Posted on Oct 27, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Code erreure sc53_01
might check the fuser(hot part) motor. Recommend get a tech to look at this problem
Jun 19, 2014 | Konica Minolta Genuine Di650 Di551 Di5510...
Sc28-03 minolta di 650
Pull out the middle assy. you will see a section that has a grill over it inside there are two/three very thin wires. They carry a very HV during the copy process not with the section out. There is a clean device on them that goes from one end to the other, your code deals with the motor that drive the cleaning device. Remove the assy., two screws front rear whole assy. comes out remove the tiny gear bring the cleaning device to the rear re-install gear re install assy. if the code comes back burn out motor, can also get a tech to turn it off for ever, not really that important.
May 08, 2014 | Konica Minolta Genuine Di650 Di551 Di5510...
SC23-03 minotlta di551
SC 23 -03 M2 Drum motor abnormality.Verify the drum drive transmission mechanism and the drum gears and collars,and the main motor drive transmission mechanism it is an mechanical blocated problem.
SC 23-01 M13 toner bottle motor
SC 23-02 M3 developing motor abnormality
Feb 13, 2013 | Konica Minolta Genuine Di650 Di551 Di5510...
SC 53-01 Service Error on Konica Minolta DI 551 - how do I clear this
1. Outdated firmware.
A flash ROM upgrade is available to correct this problem.
Notes:
a. See bulletin 3481A for details on this issue.
b. Make sure that the current version of system software (with applicable patches) is installed on the controller.
2. Improper shut down procedure of the controller.
Here is the correct shutdown procedure:
a. Shutdown the controller via the Di551 control panel.
b. Turn off the sub switch (front switch) of the printer.
c. Turn off the main switch (rear switch) of the printer.
This procedure assures that the controller and printer are properly synchronized when power is applied. If the sub switch (front switch) is the only switch
turned off, the Service Code will be generated the next time the printer is restarted.
Apr 29, 2010 | Office Equipment & Supplies
29 people viewed this question
jasbo
jasbo
