Question about Cameras
Panasonic ;SC-HC17 Compact Stereo System there is no power in the unit i have opened it and see a fuse check point, but not sure where the fuse is to check or how to replace it.
Re;SC-HC17 Compact Stereo System there is no power in the unit i have opened it and see a fuse check point, but not sure where the fuse is to check or how to replace it.
I would like to get a neew remote control for my stereo system model number CD stereo system panasonic SA-PM9
The Panasonic SA-PM9 indicates the main unit of the SC-PM9 CD stereo system. It came with the EUR7711140 remote. Amazon.uk has the original remote for sale here: https://www.amazon.co.uk/Original-remote-for-PANASONIC-SCPM9/dp/B01610BYJ8 . Other sites have replacements for this remote. One vendor with the replacement in stock (today) is http://www.remote-control-world.eu/rc-for-audio-hifi-panasonic-technics-c-12_96/panasonic-eur7711140-replacement-remote-control-p-3903 .
The manual for the SC-PM9 is available from Panasonic's support for the unit. The direct link to the manual is https://panasonic.ca/PCS/OperatingInstructions/SCPM9S-OI-Eng.pdf .
I hope this helps.
Feb 01, 2017 | Panasonic Audio Players & Recorders
There is no power to the unit
have you tried,changing the fuse......????
Nov 18, 2013 | Panasonic SC-HC3 Mini Stereo Audio System...
My new Panasonic SC-HC57 is showing a 'checking connection' message when I put in my ipod Classic into the dock. I've upgraded my ipod to the newest software through iTunes, but still no
Not all ipod classic work with your SC-HC57 you need an older Panasonic SC-HC30 to work with that ipod :( or an iphone or ipod touch to work with your SC-HC57
Dec 26, 2012 | Panasonic SCHC57 SC-HC57 SC HC57 Compact...
I need owners manual for Panasonic CD Stereo system SA-PM12
The Panasonic website might have a free PDF of it.
Feb 02, 2012 | Audio Players & Recorders
How to open panasonic sc-hc3
Model HC30DB dead; fuse in plug ok. My iPhone was docked so I had to open the door. The speaker covers do pop off, just persevere. Two screws in the CD bay; to open the door I found a small gap under the door and using a small screwdriver I could gently move a whitish cog in either direction and simultaneously applying a bit of pressure to the door, it released. Once inside, I found a glass fuse within the power supply casing, and the filament inside was melted. Now to source a new one.
Jan 18, 2012 | Panasonic SC-HC3 Mini Stereo Audio System...
Panasonic SC-AK78 The stereo lights dont come on , no sound . I i I have to turn the power on & off numerous times for it to work , the lights sometimes stay frozen ,meening if i change from stereo...
This is a sign of a power supply problem. These units use what is called a "switch mode" power supply. These use a capacitor to kick-start the power supply. While I can't say for sure, this is the most likely cause. There are other components that can be close to failure later in the circuit that can cause this as well. Without seeing the actual unit and testing the circuits, there is really no way for me to know. You should expect to pay in the $20 range for parts for this repair.
Dan
Aug 18, 2011 | Panasonic SC-AK78 CD Shelf System
Panasonic SC-HC3 micro system . 2 1/2 years old. Simply stopped working - no power light. Have checked plug/fuse connection etc but dead as a dodo! Is it best to bin it ?
The least you should do is with the unit unplugged, remove the rear cover and check for an internal fuse. It should be somewhere near where the mains cable plugs in.
Jun 28, 2011 | Panasonic SC-HC3 Mini Stereo Audio System...
POWER SURGE LAST NIGHT. SYSTEM NOW DEAD. IS A RESET POSSIBLE/
Hi:
You may have to at this point open the main unit and check your line fuse for blown condition. If found blown replace fuse with same voltage rating and ampereage rating.
Jan 27, 2011 | Panasonic SC-BT100 Theater System
Power lead in power point on no functions to the system
disassemble so you can repair power input will review all that is the power supply
Nov 25, 2010 | Panasonic SC-HC3 Mini Stereo Audio System...
Does not power on
hello there might be a glass fuse inside the unit that could have blown if not a glass fuse then a soldered in fuse called wickman
regards
shaun
Feb 19, 2010 | Panasonic SC-HT1500 System
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
