Question about Babi Italia Hamilton 6-Drawer Dresser - Chocolate
Looking to buy this piece of furniture new or used
This piece has been discontinued, wish to purchase to match crib and other pieces in set. thanks
Bassett crib model 5530-0621 purchased in 2007- how to convert to day bed? Currently have it set up as a crib
If you don't have the rails to convert, Bassett discontinued the crib in2008. You can convert it using a standard metal (bolted) frame found in mattress or furniture stores. I called customer service today and found this information. 7/15/2013
Sep 05, 2011 | Bassett Baby Gear
Tip
Modern Furniture Hardware
The choice of <b>furniture hardware</b> Your home is more than obvious that a person can get confused. In addition, the home remodeling business is very expensive, especially if you plan to connect the new design or style of interior design to his residence. But, however, will save you from all these spendings are various ways to reduce your housing costs. Even if a new piece of furniture frames and the ends have a key role to give the house a new look.<br /> <br /> <b>The first step</b><br /> <br /> Good plan <b>furniture design</b> is an important, if you do not want to go wrong at any time you want to meet your comfort and needs. You should also be aware of the style of furniture that best suits your room.<br /> <br /> <b>Replace bulky items and save space</b><br /> <br /> This is the stage where all your home remodeling. Replace bulky antique <b>furniture</b> with <b>modern furniture</b> <b>purchase </b>less space speeds are easy to handle. Antique furniture and use a large amount of space if your house is small, then choose from a wide range of<b> furniture</b> for multiple purposes. For example, with the Ottoman Empire (seat footrest + storage) or sofa bed that can make the task of both sofa and bed. A modern style, is more convenient because they tend to be smaller and clean cutting edges are not dragging a lot and therefore reduces the space they occupy. Choose a bed with storage compartments and hooks, so there is more room for better use of the box and drawer.<br /> <br /> <b>Plan before you buy</b><br /> <br /> There is no shortage of manufacturers of mobile hardware for furniture, so they are shopping in a hurry. If you've made up your mind to replace the great vintage furnishings, the latest is a fine furniture, sofa legs, so it is ready to float a little more 'before you actually find the best piece. Remember to factor measurement so that the furniture system Congratulations room. Get a tape measure and start measuring the size of the room so that you know which size is more suited to it.<br /> <br /> <b>Think Design</b><br /> <br /> This is also an important factor before buying hardware home furnishings. Modern furniture designs are different according to the taste of the designer. Some of the furniture that is modern vintage tag can not be displayed. Then, the light design that fits more at home.<br /> <br /> <b>Cut costs Window Shopping</b><br /> <br /> It is a must before buying the most coveted piece of <b>furniture</b>. Be sure to make a showcase for all points of retail<b> furniture</b> to get an idea of the whole industry of modern furniture in the furniture hardware. Compare prices of products suitable for this activity. You can also wait for furniture stores and department stores in your area for sale or offer discounts on your <b>furniture</b> before you buy one yourself.
on Feb 07, 2011 | Computers & Internet
Sea Island Crib Manual
Do a google search for Baby's Dream Sea Island drop side crib and the instructions should be the first thing that comes up. I needed the very same instructions a month ago and contacted the company by email to get them. The instructions are 2 pages long. FYI this line of furniture was discontinued :(
Jan 17, 2010 | Babys Dream Baby Gear
I am missing a piece to a crib that I received second hand. I believe the crib is a Angel Line Jenny Lind Crib according to design matches I've researched. The possible model # is 4-750-1. If possible I...
Hello. Products America may be able to assit you with your parts. You will need to be with your crib and prepared to take measurements when you call in order for them to determine if the parts you need match what they carry. The numbers are 800-205-9642 or 800-772-1041. Hours of operation are Monday thru Friday from 8am to 6pm CST. Have a great day!
Oct 09, 2009 | Angel Line Jenny Lind Crib
Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Jul 12, 2009 | Bassett Cottage 3-in-1 Crib
Juvenile llittle folks model 492790280 broken parts
You can purchase replacement hardware directly from Simmons. Here is the purchasing information:
The Simmons Juvenile Crib Furniture is manufactured by our licensee, Delta Enterprises. Please contact them directly for parts, directions, or any other request related to cribs and baby furniture. Ordering Replacement Crib Furniture Parts
Find your Model Number
  • Cribs: model number is found on a blue and white warning label on the inside bottom of the headboard.
  • Dressers: model number is stamped on the back, upper right hand side of the dresser.
Payment
  • Accepting personal check, money order, Visa or MasterCard
  • You will be charged for shipping and handling costs. Minimum billing is $8.00.
Parts cannot be returned for a refund.
Delta cannot provide parts for cribs that do not comply with federal safety standards or for cribs that are more than 15 years old.
Hope that help!
Apr 11, 2009 | Simmons Mattress Matino - Natural Maple...
Baby Crib Instruction Manual
that company went out of business do to numerous recalls for faulty cribs. personally, i recommend that you get rid of it.
Mar 09, 2009 | Baby Gear
Instructions To Convert Jardine Madison Life Time Crib
To convert your crib to a Full Size bed you will need to purchase a set of full size bed rails (hook style for headboard and foot board). You can find this at any discount mattress store, or furniture outlet, it can range in price from $39.99 - $99.99. To install the rails you will see slots with bars on the headboard/footboard, this is where the hooks on the rails slide into. There are no bolts used to secure the rails to the headboard/footboard.
Jardine enterprises does not make a wood rail kit as was shown in some of the earlier ads for the Madison line of convertible cribs, and do not waste your time ordering the rail kit from Babies-R-Us as it is simply a metal rail kit (which you may be able to get cheaper at a local furniture/mattress store).
Use the lower daybed rail between the two front posts for the foot board. Another option for the full-size conversion is to purchase the metal rails (hook style) for a headboard only and not even bother with a foot board.
If you are still unsure of what you need to do for the full-size conversion please feel free to email me at gistecknician@aol.com.
Feb 21, 2009 | Baby Gear
Where can I buy a crib piece ?
This crib has been recalled by the CPSC. don't use it. return it to where you bought it from asap. deaths have been rellated to that problem.
Feb 02, 2009 | Baby Gear
Convertible crib directions
there should be a sticker somewhere on the furniture that tells you exactly which set you have. from there you can either email them or call and they will send or fax the instructions. hope that helps.
Aug 03, 2008 | Baby Gear
Babi Italia Hamilton 6-Drawer Dresser - Chocolate Logo
64 people viewed this question
Top Babi Italia Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Babi Italia Furniture Expert? Answer questions, earn points and help others
