Question about New Balance Exercise & Fitness
Lost power cord to NB 9000 Elliptical Trainer. I need the AD adapter Voltage and Amp information to replace it
SOURCE: need to replace lost power cord fpr back pack bantam 181100
the factory power transformer is 5V 1 A model TRX-022A input is AC100-240V 50/60 Hz 0.15A output DC5V 1A
Posted on Dec 29, 2008
SOURCE: Need the specs on adapter for JUSTer dc-691p speakers.....
Model: PPI-0930-UL
INPUT: AC 120V 60Hz
OUTPUT: DC 9V 300mA
Polarity: Neg.outside, Pos.inside
Posted on May 19, 2009
SOURCE: Need power adapter for an SP-645ME-A1, MODEM ADSL 645ME-A1 Sprint
Found the answer on DSLDepot.com.
Posted on Jun 23, 2009
tolexade
  • 81 Answers
SOURCE: Bad power supply WD external harddisk WD5000E035-00
the adaptor is absolutely bad you have to change your adaptor, since it cant receive power any more it is not advise to fix it
Posted on Jul 19, 2009
  • 6 Answers
SOURCE: Burn fan/poweradapter
Hi!
If anyone would like a Power adapter for their Ultra LCD30-500 and LCD40-500 - please email me Acosta.cal@gmail.com... And I’ll be able to order one…
Posted on Aug 19, 2009
Can anyone provide me with a manual for the Torpedo Elliptical Cross Trainer
Manual for Torpedo Elliptical Cross Trainer - Fixya
www.fixya.com/.../t3961893-manual_torpedo_elliptical_cross_trainer
Jan 24, 2010 - Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to ... Dear Sir: Please ...
Nov 23, 2015 | Exercise & Fitness
Why is the Precor AMT 100i Adaptive Motion Trainer Elliptical primary belt making noise and should I adjust it?
SOmetimes belts make noise when they are worn out and need to be replaced - belts like that are considered 'wear' items, like tires on a car - they have a very limited lifespan compared to the other parts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Jun 18, 2014 | Precor AMT 100i Adaptive Motion Trainer...
Power supply
Call Treadmill Doctor at 800-750-4766, they can steer you in the right direction.
Jun 16, 2012 | Multisports Elliptix Ect 6600L Cross...
The power cord for my schwinn 430 elliptical no longer stays plugged into the machine. I have to push it really had into the bike outlet so the machine turns on, but as soon as I take my hand off of it,...
Do you think the power cord is going bad? If so here is the parts list for the Schwinn 430 if you need to order a new AC adaptor. If you think the connection inside the machine is going bad you may want to find a servicer to look at it.
Apr 19, 2011 | Schwinn 430 Elliptical Trainer
My Schwin 430 power cord socket went inside the machine. Please advice how to power the machine.
There should be a series of phillips head screws (star) holding the black casing together. If you remove the 2 or 3 screws along the immediate front of the case, you should be able to open it up just enough to see the outlet. It's a small plastic piece about the size of a grape attached by two wires (red and black). The outside of the outlet is threaded so when it's pushed through the hole, you thread a nut on the outside to hold it in place. If you've lost the nut, you can easily tape the outlet in place, or just run the ac adapter cord in through the hole in the case, use the opening at the front you made by removing the screws and plug it in on the inside to power it. Replace the screws and just make sure you keep anyone from yanking on the power cord.
Jul 06, 2010 | Schwinn 430 Elliptical Trainer
I have an Eliptical Trainer BY-430E. I keep getting Error 1 every time I turn it on to use it. Does anybody know how this can be repaired. Thanks in advance
Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
Jun 28, 2010 | Schwinn 430 Elliptical Trainer
Power cord?
you can find the power cord at fitnessrepairparts.com
Jun 02, 2009 | Schwinn 430 Elliptical Trainer
Exercise & Fitness Logo
170 people viewed this question
Top New Balance Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Howard
Howard
Are you a New Balance Exercise and Fitnes Expert? Answer questions, earn points and help others
