Question about Alpine TDM-7546
Clock alpine tdm7526
No time
I purchased a used Suburban in which the previous owner installed an Alpine CDM-7857 receiver. Although I do not have the Alpine owner's manual I figured out most the receiver's operations except how to...
According to the manual follow these steps
While the clock is displayed, hold down the clock button for 3 seconds.
Time indicator will blink.
Press the ct button to set the seconds.
Press the H button for the hour.
and M for minutes.
Time indication will stop blinking 5 seconds after the ajustment.
Then the time will automatically be set.
Just in case I will include the link to the manual for other operations.....
http://vault.alpine-usa.com/products/documents/OM_CDM-7854.PDF
Jan 10, 2011 | Alpine CDM-7857 CD Player
How do you change the time on the clock? Don't
This is from Page 7 of the manual available on Alpine's site:
moz-screenshot-1.pnghttp://vault.alpine-usa.com/products/documents/OM_CDA-9884.PDF
Setting the Time
1. Press and hold F/SETUP for at least 2 seconds to activate the SETUP selection mode.
2. Turn the Rotary Encoder to select CLOCK ADJUST,
and then press "magnifying glass"/ENT
3. Turn the Rotary Encoder to set hour.
4. Press "magnifying glass"/ENT
5. Repeat steps 3 and 4 above to set minute.
6. Press and hold F/SETUP for at least 2 seconds to return to normal mode.
I hope that helps.
May 21, 2010 | Alpine CDA-9885 CD Player
How do I set the clock on my Alpine stereo, Model CDM 9801?
From Page 6 of the CDM-9801 manual from Alpine's site:
http://vault.alpine-usa.com/products/documents/OM%20CDM-9801.PDF
1. In the Clock priority mode, press and hold the
DISP button for at least 3 seconds while the
time is displayed. The time indication will blink
2. Turn the Rotary encoder to adjust the hours
while the time indication is blinking.
3. When the hour has been adjusted, press the
Rotary encoder.
4. Turn the Rotary encoder to adjust the minutes
while the time indication is blinking. The time is
automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder.
I hope that helps.
May 11, 2010 | Alpine CDM-9801 CD Player
With clock shown, press and hold the display button for 3 seconds. The time will blink. Turn the rotary encoder to adjust the hours while the time is still blinking. When the hour is set, press the rotary encoder. This will switch to minutes adjustment. Turn rotary encoder to adjust minutes. Press rotary encoder once minutes are set or wait 5 seconds and time will store automatically. Reference page 6 in this link to Owners Manual for Alpine CDM-9821.
http://vault.alpine-usa.com/products/documents/OM%20CDM-9821.PDF
Oct 14, 2009 | Alpine CDM-9821 CD Player
How do you set the clock on an alpine tda-7552
Wow that is an old Alpine cassette deck? Ok if memory serves me correctly do you have a little button labeled "clock"? If so hold it down for a few seconds till it starts blinking, than using preset 5 for hours and 6 is for minutes when you set the correct time press the clock button again to save the time you set.
Jul 25, 2009 | Alpine Car Audio & Video
How to adjust TIME on Alpine CDE-7856
Once you get the time blinking it is buttons 5 (hour) and 6 (min) that adjust the time.
These are channel buttons on the far right: they are green and are on the bottom edge.
Feb 26, 2009 | Alpine CDE-7826
Clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Apr 26, 2008 | Alpine CDE-9843 CD Player
How to adjust the clock?
According to the manual you hold the clock button in for a least 3 seconds. The time indication will blink for about 5 seconds.
Press the CT button while time indication is blinking to set seconds to "0".
Press H button to adjust hours and the M button to adjust minutes.
The time indication will stop blinking, 5 seconds after adjusting the minutes.
Oct 22, 2007 | Alpine TDM-7545
Clock setting for Alpine CDE-7826P
Push the clock button until it flashes. Then push '5' for hours, '6' for mins until you get to desired time.
Aug 04, 2007 | Alpine CDE-7826P
Car Audio & Video Logo
15 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
