Question about Saeco Aroma Espresso Machine
Suddenly can't get coffee (or water) to come out of my Saeco Aroma porta filter.
Started failing two days ago, same grind as always. Tried descaling, didn't help. Running water through a basket, will sometimes clear it after a popping sound. Is the porta filter repairable?
  • 83bj60 Mar 10, 2014
    In case you hadn't solved your problem and still have the machine (sorry, I don't come here often and there is no email announcement system here), here's what is likely wrong, in order of probability: 1) The basket is clogged up. Take the basket out and make sure you can see through the holes. It may be clogged up. Use a stainless steel wire brush and ammonia household cleaner. Very effective! 2) The portafilter valve mechanism is gunked up. Fill the basket with household ammonia cleaner, get the machine hot then run the pump, a few seconds at a time. It should clean all the 'tar' off the valve and mechanism and get the flow going again. You can repeat the process, it doesn't harm the innards. Rinse well after this, otherwise your coffee is going to taste awful ;) 3) The portafilter mechanism may be worn out, burned or otherwise defective. it's quite delicate and there are small springs that can fly apart especially the feather spring so it's best to have Saeco replace it for you, but if you're handy it's fairly simple to do. Last time I did mine it cost me something like $20 of parts. 4) The head outlet valve could have cooked onto the outlet, but it usually leaks instead. It can be hard to remove it, but the parts are inexpensive (a small mushroom shaped silicone and a spring) 5) The pump may have failed. If your machine is old, it could well be that your pomp has gone weak, in which case it would have to be replaced. When it's time for a new pump you got to ask yourself if it's worth replacing it, or getting a new machine, as the part is expensive, it's time consuming and by the time it fails, other parts have also gotten old. I have such a machine I keep for parts. If you find typos... the Comment system here is horrible, can only see one line at a time. Sorry!
    Not only is the comment system input horrible, but it also doesn't respect paragraph formating. Fixya, what happened???
mirran
  • 515 Answers
SOURCE: My Saeco Aroma Expresso machine has water leaks
I think you have to replace the gasket in the machine where the portafiller fits on the machine.
Make sure your filter is clean before you replace any gasket.
/Mirran
Posted on Aug 23, 2008
  • 3 Answers
SOURCE: Steam nozzle leaking
Hi! hope i'm not too late, since this leaking problem occur's quite often, specially when one's tends to overtight the valve, the proposed solutios will certainly help thousand of happy Saeco owners.
Anyway i happened to live with it but after a second valve replacement, i got fed up with filling too often the reservoir and fixed it at Zero cost. What i did is realy easy:
1- Find a bearing the size of the plunger of the needle valve; the thiny steel ball in a nail polish bottle is what i used.
2- When the electric cord is pulled off the wall outlet, take the cover off, reach to the snap locker and pull it off.
3- Unscrew the needle valve plunger off the cylinder, grind or file the
tip 3/16 of an inch, making sure it is at rite angle cut.
4- Insert the ball in the valve body and push it with the flattened tip
over the vapor down stream and screw. You now have a new valve that will outlast your coffe maker.
Posted on Jan 21, 2009
EsWorld
  • 1618 Answers
SOURCE: Seaco Easy wont work/Warning light blinking always
Try descaling the machine. If there is no water getting to the brew unit then it might be blocked, if you checked the brew unit then the blockage might be at the boiler or one of the lines.
Posted on Jun 04, 2009
  • 1089 Answers
SOURCE: weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Posted on Nov 25, 2009
  • 1089 Answers
SOURCE: I have a Saeco Royal
Hi
Its not the water. More than likley its the lever on the right side of the machine at the top middle of the door. Its pushed all the way to the back or positive. Move it 1 mark towards the front of the machine and try again. If you put too much coffee in the brew unit, it can't compress it and kicks it out. It could also be your grind is too coarse. It should look like auto drip coffee.
Posted on Apr 03, 2011
Few days ago, the brewing light on my Aroma Seaco coffee machine does not turn on anymore. I could still make coffee but I noticed that the water took a longer time than usual to warm up. Yesterday, I had...
Clean the porta filter mesh by sm all pin.if you have pressurise filter basket then you have open it.because pressureise filter basket contain 2nos mesh .one mesh is multihole and another is single hole .you have clean both.
Jan 28, 2015 | Aroma Coffee Makers & Espresso Machines
Grinds coffee but no water comes thru dumps dry grounds into hopper then stops. A couple of times it has worked ok but then goes back to the same problem. Ahhhhh I need my coffee
Sounds like the grinder is grinding too much coffee than the brew unit can handle. Otherwords itis overloading the brewunit. Try reduce the aroma in the coffee menu to mild.
Jul 12, 2010 | Saeco INCANTO DELUXE Espresso Machine
Trobleshooting saeco coffee machine
with the water tank fill open the steam wand with hot water setting to re-prime the system or ventilate it
Dec 13, 2009 | Saeco Aroma Espresso Machine
Weak coffee saeco vienna "not digital "
Hi
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco Aroma now only produce bitter coffee...
besides a good coffee machine, 2 things are critical when you want a good cup of coffee; the coffee itself and the water. When in France, i tasted some of the best coffee I have ever had, but they always told me that the quality and purity of the water made for 50% of that great taste. Has your municipality changed anything about the water treatment recently? Do you drink that same water and find it tastes funny? Perhaps bottled water is a solution in your case. Hoping this helps.
Marc
Feb 03, 2009 | Saeco Aroma Espresso Machine
Saece Talea - Dispensing failed
Take out the brewing unit and clean it in hot water.
/Mirran
Aug 30, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
/Mirran
Aug 22, 2008 | Saeco Aroma Espresso Machine
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Jul 19, 2008 | Coffee Makers & Espresso Machines
My saeco aroma gets blocked.Sometimes he water will come out and other times it won't.
Hi!
Had this problem. Fixed it by taking off the O ring at the bottom of the porta filter and turning the bottom plate under the water stream. Doing that every 3 - 4 day will certainly help.
Jun 26, 2008 | Saeco Aroma Espresso Machine
Coffee Makers & Espresso Machines Logo
46 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
