Question about HP LaserJet 600 M602DN Laser Printer - M
Laser Jet P603 cold Reset - HP LaserJet 600 M602DN Laser Printer - M
How to reset expired hp 02 cartridge
I'm not sure what you mean by "reset" and whether you are speaking of ink jet or laser cartridges. From my experience all HP laser cartridges have a small chip (with a little circuitry) that counts down your pages and when it decides your cartridge is out of toner you cannot "reset" that chip, you can only replace it, so like when you refill the cartridge. Some of the HP laser printers let you override these toner level chips (my HP 1518ni does) but in many laser printers you are stuck when the chip counts down to '0' pages. Some printers will run if you remove the chip from the cartridge but from my experience most will not.
Ink jet cartridges are somewhat similar but I gave up on ink jet printers several years ago. I know for some brands (Epson?) you can buy a small tool that somehow resets the cartridge chip (so if you refill cartridges yourself); possibly there is something similar for HP ink jet cartridges.
Feb 13, 2015 | HP Office Equipment & Supplies
Cold reset of hp laser jet 4345 mfp
Turn off printer. Power on and watch the display, when the memory count starts, press and hold "6" on the keypad. Keep holding until the three lights on the control panel stay on. Release "6" and then press the "3" button until display reads "cold reset". Then press the "6" once more and until will reset.
Mar 07, 2014 | Cameras
I have an HP 5500 color laser jet that is missing the cyan color when printing. I have replaced the print cartridge, contacts of high-voltage PCB, laser/scanner, high-voltage PCB and the DC controller,...
To fix this problem it is best to reset the HP Printer to its Default settings. Follow these Steps and This should fix your problem.
Step1: Turn the Printer on.
Step2: Watch the Control Panel on the printer.
Step3: When the Memory starts counting, press and hold the Green check mark button also known as select. Continue to hold Select button until all three Control Panel LED's are lit up and solid on.
Step4: Release the Green Check Mark Button (select)
Step5: The control panel will display SELECT LANGUAGE.
Step6: Press the Down Arrow until the control panel displays COLD RESET.
Step7: Press Green Check Mark Button (select). The Printer will perform a cold reset and then continue its power-on sequence.
Apr 29, 2011 | Office Equipment & Supplies
The jet direct card is not showing up on the configuration page
Two possible problems:
1. Bad formatter, not liklely if you have used this printer with this jet direct card for a while and have not removed the card from the printer.
2. More likely either bad or in need of reset jet direct card. I am going out on a limb and guessing that you have a Jet Direct 615 card. There is a small chance that the card just needs to be reset. To do this you must perform a cold reset of the printer. Any custom tray settings that you have made will be lost during this process as will any network settings. To cold reset, turn printer off and unplug the network cable. Hold the "checkmark" key and power on the printer. Keep holding the key until all three leds turn on solid. Release the checkmark key and use the arrow keys until "COLD RESET" shows in the display. Press the checkmark key and until will perform a cold reset and restart. Plug your network cable back in and print a configuration page. If card is working again great, if not, it is likely that the card is dead and will require replacement.
If card does work, you will want to ensure that the Jet Direct card has current firmware on it. Use the HP Download Manager to update the firmware on your Jet Direct card.
Good Luck.
Apr 18, 2011 | HP LaserJet 4200 Printer
I use Laser Jet 4200tn printer. It print very slow about 10 page/min. Slove my problem
try to perform Cold Reset,
maybe this will help you to solve your problem!
If not - visit HP service.
To do this just follow this simple steps:
  1. Turn the printer power off.
  2. Disconnect any Input/Output devices (JetDirect cards, etc).
  3. Hold down the SELECT (Checkmark) button, and then turn the printer power on.
  4. Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
  5. After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until COLD RESET is highlighted.
  6. Press the SELECT (Checkmark) button. The printer performs a cold reset and then continues its power-on sequence.
  7. Check all I/O settings and reset any customer-set printer configuration values.
for more information chek this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00023439&locale=en_US
Good Luck!
Mar 21, 2011 | Office Equipment & Supplies
HP 4200 Laser Jet Printer Error Code 82.0180 EIO 2 Error
The error message "83.0180" shows that an EIO error has occured.
Perform the following workaround and see whether the issue still persist.
1. Ensure that the printer is connected directly to the wall outlet.
2. Turn off the printer and then power on and see whether the issue persist.
3. Reseat the Jetdirect card and see whether the issue still persist.
4. Reseat the jetdirect card on a different slot and see whether the issue still persist.
5. Remove all the accessories from the printer and then power on the printer. See whether the issue still persist. If the issue does not persist, add on the accessories onee by one.
6. Power on the printer and check whether the issue persist, each time an accessories are added.
7. Swap the Jet direct card with a known good jet direct card and see whether the issue still persist.
8. Perform a cold reset and see whether the issue still persist.
To do a Cold Reset:
1. Remove all cables.
2. Press & hold the Test button while applying power & continue to hold it for 10 seconds, then release it for 10 seconds, then unplug it again.
3. Connect all cables & power it back up.
4. Wait 2 minutes for discovery & DHCP. If desired, change the DHCP & address settings.
May 07, 2010 | HP LaserJet 4200 Printer
I have an error code 58.04 on my hp color laser jet cp3525n can you help me out to reslove this error
8.4 suggests that engine power supply failure. The engine power supply mounts in the middle of the machine under where the toner cartridge resides. Lots of work to get to, I'm afraid. Need a service manual? Check out the link below. . .
http://www.image1products.com/techdocs/HP.htm
You could try cold reset:, if you can?
1. Turn printer off.
2. Hold the GO key
3. Turn printer on.
4. Continue to hold the GO key until the printer reads COLD RESET.
5. Release GO.
- INITIALIZING appears.
- Then, RESTORING FACTORY SETTING.
- Followed by OFFLINE.
6. Press the GO key to put back on line.
NOTE: A cold reset resets the HP Jetdirect card. Remove HP Jetdirect card before performing a cold reset
Apr 09, 2010 | Office Equipment & Supplies
I have installed A Sagem DTR67250T 250gb with the scart & RF leed supplied . When I checked the signal strength I have 98% on both lines ,but the top line is red indecating poor the bottom line is...
I am also getting his p603 error on my DTR67250T. I saw on another site that it indicates a problem with the power supply and should contact Sagem Technical Support on 0845 0900316 to get a new one - said it would be 10.
Mar 01, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Jan 02, 2009 | HP LaserJet 2420dn Printer
Hello i have hp color laser jet 4700dn printer when its print from computer its s howing message 49.3048 service error how can i solve this problem .please can u advace
This is a communication error. Make sure there isn't anything in the print que. If there is try deleting it. Unhook the printer from the network or computer and try and powercycle the printer. If that doesn't work try a cold reset. Turn the printer on and once the memory starts to count up press and hold the check button until the three lights light up and release then scroll down and hit the check mark on cold reset and see if the printer comes to ready. This will reset the IP address if the printer has one
Dec 24, 2008 | Office Equipment & Supplies
HP LaserJet 600 M602DN Laser Printer - M Logo
42 people viewed this question
Seeker5211
Seeker5211
