Question about Samsung Freezers
Samsung srs584dp fridge freezer not cold - Samsung Freezers
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
How do you use an arcelik duo cold fridge and freezer
Hi Emma,
You may want to check this site for your queries if it is fridge or freezer. Hope it helps.
Why should buy Arelik Refrigerator and Deep Freezer
Apr 25, 2014 | Freezers
My Samsung RS21DPSM is not freezing, the fridge is working and the fan in the fridge is not loud. The freezer is not freezing.
Check the condenser fan in the compressor department. The fan motor is know to fail. The refrigerator and freezer temps will be cool but not cold. I would start there.
Apr 02, 2014 | Freezers
Fridge of fridge freezer does not get cold (bosch excel KGN34X61GB-05)
Sounds short of refrigerant or very blocked up condenser. Is there a lot of heat from the back/ underneath>
Mar 21, 2014 | Freezers
Fridge not working but freezer is ok fridge light works
There is probably an ice build up between the two sides of the appliance. There may also be a problem with the damper unit which controls the cold air coming from the freezer side to the fridge. The fridge is controlled by the freezer. Dependant on appliance. The door opens and closes letting the cold air go into the fridge and when the fridge is cold enough the door will close agin. This is not something that you will see happening it is normally concealed behing a diffuser.
Feb 24, 2010 | Freezers
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
Samsung cool n cool freezer & refrigerator does not cool
samsung refrigerator won't cool how do we fix it?
Apr 14, 2009 | Freezers
Samsung fridge/freezer model SRS73DTA doesnt freeze.
Hi I have the same problem,
did you get an answer to your question..?
Jan 19, 2009 | Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Freezers Logo
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
