Question about HP Pavilion dv9933cl PC Notebook
Manual service I have a dv9933cl where randomly the screen will flicker or the colors will be wrong on part of the screen. is this a cable or chip problem or is the only way to tell is to replace the cable and see if it still happens?
    Top Expert:
  • HP Master
  • 26,196 Answers
It is probably a GPU overheat issue where the BGA chip has desoldered itself.
Reballing the GPU should fix it.
Posted on Nov 20, 2013
Picture problems with flickering screen and peppered black dots.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 03, 2015 | Televison & Video
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Screen flicker
Check the ram first then check the screen cable
Nov 20, 2013 | HP Pavilion dv9933cl PC Notebook
I have an HP dv9260nr. Intel Core 2 Duo @ 2Ghz. 2GB Ram and GeForce Go 7600 When I turn it on I see lines on the screen during boot. they are like red green and blu dotted lines. the color is kinda...
Repeat your video cables and look for bent pins. If that don't work reseat your video card unless it's integrated video in which case you would need a new motherboard.
you could also try and revert to an earlier restore point. Press F8 when you restart your system
Oct 20, 2017 | HP Pavilion dv9260nr Notebook
Flickering screen Toshiba P105
Flickering, always cause by LCD cable. Change it at any computer shop or service center and its not so expensive
May 08, 2010 | Toshiba Satellite P105-S6104 Notebook
Flickering screen, loud buzzing sound, self boot down.
Color wheel bad. Makes rumbling sound. Bad bearings. Has to spin about 10,000 RPMs and sync to DLP chip. Here: https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5933777&smodel=HLR5067WX/XAA
May 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My Toshiba A205 started up with a distorted screen. The Toshiba start up screen has yellow letters on a green background. The blue log in screen has swirls of distortion. I can read the text in any program...
Try repositioning the screen in different angles. If it clears up even if only for a minute, the it is most likely the cable or ribbon cable running from the LCD to the motherboard. If not, It may still be a broken wire in the bundle or something more serious like the inverter card or the video chip. The wires on the bundle usually break over time at the point where the bundle runs up by the hinge of the LCD.
Jan 11, 2010 | Toshiba Satellite A205-S5804 PC Notebook
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
HP Pavilion dv9933cl  PC Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
