Question about Measuring Tools & Sensors
Need pdf manual for sharp SPC1003 clock - Measuring Tools & Sensors
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
Sharp user manual for model SPC1003
Go to sharp web site and search your model.
Aug 25, 2014 | Microwave Ovens
I have a Sharp Corousel Microwave R230KW.
On most Sharps, the sequence is:
Clock > 2 > 3 > 5 > Clock (for 2:35)
or
Clock > 2 > 3 > 5 > Start (for 2:35)
You can order many Sharp manuals free here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 26, 2009 | Sharp Microwave Ovens
Don't know how to set clock on it! Still working well, however.
http://www.usersmanualguide.com/sharp/microwave/r-242m
Theres your manual...
click Download
R-242M pdf user manual
Then either click view or download...
Apr 24, 2009 | Sharp R-242 Microwave Oven
How do I change the date on my Sharp OZ 590A PDA
Menu > clock > edit on the bottom of your screen, scroll through and alter from there
Jul 17, 2007 | Sharp Wizard OZ-590A
Measuring Tools & Sensors Logo
77 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
