Can't dissassemble avanti mini pub
Need to take apart without breaking it to troubleshoot power continuity problem . i've removed all screws but it will not come apart
  • craig steven Prentice
    craig steven Prentice Nov 20, 2013
    somehow this got categorized as a laptop - it's not a laptop - it's a mini beer dispenser - avanti mini pub MBD5L
    THANK YOU FOR YOUR EFFORT , ANTHONY .... oops sorry for the caps
5 Suggested Answers
SOURCE: Disassembly of case
This is for a Viewsonic VX900. The bottom bezel with the button unclips.Unplug the connector, and put aside. ( Dont pull on the wires) Then there are two screws that are removed, and the grey frame around the monitor comes off next. Then remove the 4 bottom screws, and the two top tiny screws and the LCD comes away from the back. Remove the shielding, and replace your components. Good Luck !!
Posted on Oct 27, 2007
SOURCE: I'm trying to disassemble my
that for the lg chocolate slide, I'm in the same situation as you, any help would be much appreciated.
Posted on May 21, 2008
  • 25 Answers
SOURCE: Power head and wand connection is intermittent.
If there is a rubber bumper on your power head you must slip it off before the two halves will separate.
Posted on Aug 29, 2009
ZJLimited
  • 17970 Answers
SOURCE: Dissassemble of Radiator
Instructions
Things You'll Need:
  • Resealable container
  • Wrench
  • Replacement hoses, if necessary
  • Replacement radiator
  • Engine coolant
  • Distilled water
  1. Disconnect the negative battery cable before you begin the process of replacing the radiator. Then, remove the plug on the underside of the radiator and let the engine coolant drain into a resealable container.
  2. Remove the upper radiator hose and lower radiator hose. Inspect the hoses, and if they need to be replace, this is the perfect time to do it. Unfasten all of the bolts with a wrench, securing the grill reinforcement panel, and take off the panel.
  3. Unhook the transmission cooler lines, along with any electrical connections. Take off the radiator mounting support bolts, and remove the radiator support. Remove the bolts holding the radiator in place, and lift out the radiator.
  4. Slide the new radiator into place, and tighten the bolts according to specifications. Reattach the radiator support and the radiator mounting support bolts.
  5. Reconnect the electrical connections and the transmission cooler lines, and replace the grille reinforcement panel. Reconnect the negative battery cable.
  6. Fill the radiator with a mixture of half engine coolant and half distilled water, pouring slowly to avoid excess air.
  7. Start the engine and let it run for several minutes with the cap on very loosely to bleed air from the system, then top off the engine coolant mixture, if necessary. Replace the radiator cap securely.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
  • Don't waste good engine coolant. If the coolant is clean, it can safely be reused. If you're unable to reuse it, take it to a garage or a hazardous waste facility for proper disposal.
  • Be sure the engine of your Jeep Grand Cherokee is completely cool before replacing the radiator because the hot liquid and steam can cause serious burns. Put a thick towel over the radiator cap and open the cap very slowly to allow any steam to escape. It's also a good idea to wear gloves and protective clothing.
  • Remember that cats and dogs are attracted to antifreeze, which can be fatal if ingested. Clean up any spills as soon as they happen.
Also, can review the service repair manual for 1995 Jeep XJ Cherokee (Section 7 Cooling System)
I hope help you with this (remember rated this help). Good luck.
Posted on Oct 02, 2009
Laptop screen replacement
If you've removed the screws that is on the plastic that is around the outter edges of the screen then use a little force with your fingers to pry the plastic bezel apart from around the screen. Normally this is snuggly snapped into place around the screen. Surely some knucklehead did not apply glue to it.
Mar 10, 2012 | Computers & Internet
How to dissassemble Vidal sassoon VSCL816. (e.g. scissors area). two phillips scresw unscrewed, but two shells of housing cannot be separated completely. Hint needed for taking away scissors. Scissors got...
I have a Vidal Sassoon Max hair clipper, and I suspect the construction of it is similar to yours. To take the two halves of the body shell apart you need to remove the blade assembly. Try this:
After removing the two visible screws, place your thumbs at each end of the cutting blades and push upwards.
The blade assembly should unclip, revealing two more screws underneath. Remove these, and the two halves of the body shell should come apart.
Graham
Apr 10, 2011 | Vidal Sassoon VSCL816 Beard Trimmer
I want to replace a motherboard on a HP dv1040us. How do I get it apart without breaking anything?
http://h10032.www1.hp.com/ctg/Manual/c00636251.pdf
go to this web site and go to the scew listings , you shud take a look at it before trying because they are showing you where the screws are but they aren't in the order on to dissassembling it , this does not show you step by step on how to take it apart but it will help you on figuring out how to take it a part , even tho if you dont kno how to change it on a laptop you shouldn't because there are cables you could damage , but if you take it apart i would suggest being cautious
Feb 21, 2010 | HP Computers & Internet
Aug 21, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Video card screwed on presario v3000 (known issue)
The mainboard or motherboard is the main PCB in the laptop. It is the most difficult component to replace because you must completely disassemble the laptop to remove it and properly install the new one. Take the battery out, ground yourself and discharge the laptop by pressing the power button for a few seconds. Most laptops start dissassembling by removing the power button/led panel above the keyboard, and then removing the keyboard, de-attaching the LCD screen assembly. And then flipping it over and removing screws on the bottom, then the laptop will split in two peices, the top part of the chassis and then the bottom half which is where the motherboard will be attached. If you decide to continue organize your screws, label them or take pictures to help you get it back together. Hope this helps you get started.
Dec 16, 2008 | HP Compaq Presario v3000z Notebook
Screen blacking out.
Hi, I used to fix a monitor from Dell. There are 4 screws at the back of rear panel and no screw at front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off.
For the metal plate that shields the back of the screen, There are some screws you have to deal with. Those screws are at the power and screen connectors.
Thank you,
Tan
Mar 01, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
HOW TO OPEN cASE
After you remove the stand, there is a metal plate under it which will come out. Underneath that there is one more screw, (the last one). After that, carefully pry the case apart.
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Avanti er24aw1
Call avantiproducts.com sales (service didn't work) and get a replacement bake element. It was about $35 including shipping. Download the manual from the site and study the structure. Uncover the back cover using standard phillips screw. TO DO THIS, SHUT DOWN YOUR HOME BREAKER AND MAKE SURE THE OVEN OPERATION LUMP DOES NOT LIGHT. OTHERWISE YOU WILL BE EXPOSED TO HIGH VOLTAGE. Additionaly use multimeter to make sure the voltage is not there. Remove back inner cover. You can't remove this inner cover completely because of the thermostat line but try to make a work space in the lower part of the oven. The bottom element cover can be uncovered readily without any screw or pin. At this point you have access to baking element from the bottom of the oven. Loosen two nuts to remove the bad element. Reverse the procedure to install the new element.
Dec 03, 2007 | Avanti ER24AW-1 Electric Kitchen Range
Computers & Internet Logo
David Payne
David Payne
