Question about Philips SoundBar DVD Home Theater with Ambisound
I dont have Aux in function in my philips home theatre model lx2600d Is there any way to create aux in to my philips home theatre?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Philips Master
  • 924 Answers
Does your unit have any analog inputs? If you only have digital inputs, you can purchase a analog to digital adapter. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 21, 2013
  • 1779 Answers
SOURCE: Philips LX3600D Home theatre always returns to standby mode
There is a 1ohm resistor on the 4x4 pcb as soon as you take off the cover. ( I forget the ID # ) It supplys the -15volts to the control bd. The resistor will not looked burned. It was under rated. An ohm meter will find it ( open ). Rreplace it with a 1/3 watt. I believe the orig. was a 1/4 watt.
Posted on Apr 11, 2008
SOURCE: Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
Posted on Dec 08, 2008
easyq
  • 144 Answers
SOURCE: Installing help
check on www.philips.com and search for HTS3450, all setup details are available there.
Posted on Apr 17, 2009
SOURCE: philips home theatre dvd player loads and says no
did ya plug in those three colored plugs
Posted on Nov 07, 2009
SOURCE: Hi my Philips HTS6510 Home Cinema is frozen, it just shows
Hi, mine is also blocked, completely frozen. it also shows AUX and won't react to anything. Have you already solved the problem? Whad dit you do?
thx for the effort to reply,
greetz
Posted on Mar 25, 2010
How do i connect my pc to my phillips home theatre system through an hdmi cable
The best way is to connect your laptop to a spare HDMI input on your TV first, then use the AUX OUT from your TV to the AUX IN1 of the Phillips Home theatre system using a standard RCA cable.
The only catch with this is that you will have stereo analog audio, NOT digital surround. However, by pressing the "SURROUND" button of your Phillips HTS remote you can switch the audio output to multi-channel surround, stereo or party mode.
What is the model number of the TV you are using?
Oct 23, 2012 | Philips HTS-3565 Theater System
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
How do you get sound to come from tv out of speakers of home theatre system
It just depends on the tv you have. If you hook up the RCA jacks to the (Audio out) of the TV into one of the (AUX in) ports of the home Theatre system you should be able to geet the sound that comes from the TV to play out the theatre system. If you are watching through a cable box you will need to hook the RCA cables to the cable box (Audio out) too the theatre systems (AUX in), in insted.
Mar 05, 2011 | Televison & Video
I recently bought Philips DSP 2500 Home Theater ... i dont have a cd player nor any dvd players. i want to connect it to my pc or my cellphone through aux .... so any sollution 4 this .... m planning 2...
hi! i am the computer expert i will solve your problem , just buy 4nos. 3.5mm jack(without wire connected) . Buy 3meter wire and solder it with one for pc and other 3 for the home theatre.
For more information contact: athibanbirla@yahoo.in, billa_2010@rocketmail.com, rathiban1998@yahoo.in, sachin_vvb@in.com, Ph. no +9104522381424 .
Got It
Oct 25, 2010 | Philips MMS 460 - PC multimedia home...
Hi can i connect my transcend mp3 player directly to my home theatre so that i can get the music output in my home theatre speakers , if i can please suggest how?
easy, just find the AUX port on the home theatre system then turn the system to AUX and hook a cable that has 2 male ends (the ends that go into your mp3 players headphone jack) to your ipod and to your home theatre, you will have to buy this cable seperatly
Jan 03, 2009 | Transcend T-Sonic 840 MP3 Player
Installing help
Jan 02, 2009 | Philips HTS3450 System
I'm trying to get the xbox working through the home theatre system but I'm still getting the sound from the TV which has intergrated freeview. The Xbox is connected to the TV using an HDMI cable, the home...
you need to hook up the xbox' audio cables to the home theatre systems AUX in port and then have your system set on AUX, and you can leave your xbox' hdmi plugged into the tv, just be sure your on the correct AV chanel.
Dec 24, 2008 | Panasonic Home Theater System System
No sound comes out of my home theatre hen i plug it on my tv
hello
use the link below to check out if this is your tv. http://www.p4c.philips.com/files/2/29pt4273_75r/29pt4273_75r_dfu_eng.pdf
if it is, then go to page 5 in the manual.
connect L/R from monitor out to the AUX of your amplifier. when you want sound from the tv, select AUX as source from the front panel of your amp.
hope this helps
May 24, 2008 | Audio Players & Recorders
No sound when connecting to TV
I just figured it out right now. Press the "AUX/DI" button twice. When you push it once, it selects the "AUX" input and when you push it a second time, the screen will show that you've selected the "DI" input.
Thanks to Phillips for not making a theatre system that automatically selects for you... =P
Jan 22, 2008 | Philips HTS3450 System
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Philips SoundBar DVD Home Theater with Ambisound Logo
60 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
