Question about Ricoh Aficio AP3800C Laser Printer
Ricoh sp c430dn won't print cyan
All colors except cyan are printing
jaylex
  • 417 Answers
SOURCE: Smearned Printing on Ricoh Aficio AP3800C Laser Printer
Hi there the smudges are most likely down to the black PCU (Drum Unit) and following are the reasons for the two fault caode you have given me.
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
SC 380 Black
development
motor error
SC 381 Color
development
motor error
When the motor speed is
within the target level, the
motor sends a lock signal
(High to Low at CN214-5) to
the BCU.
SC380 is detected under the
following conditions:
• The Lock signal stays High
2 seconds after the motor
turns on.
• The Lock signal stays Low 2
turns off.
for more than 2 seconds
while the motor is on.
• Defective motor
• Defective BCU
2. Replace the motor.
3. Replace the BCU.
Hope this is any help
Thanks J
Posted on Feb 21, 2008
  • 86 Answers
SOURCE: Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
Good luck and please rate me, thanks.
Posted on Feb 12, 2009
  • 95 Answers
SOURCE: Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Posted on Apr 23, 2009
  • 161 Answers
SOURCE: not printing double sided
check the driver
does not print from bypass tray (manual feed)
does not print on thick paper (check paper type)
Posted on May 06, 2009
Dicedonions
  • 118 Answers
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Posted on Apr 29, 2010
HOW TO OBTAIN PRINTER READINGS FROM MACHINE RICHO AFICIO SP C430DN
Hi.
You will need to print the Printer configuration page.
The procedure is;
Menu > Printer Features > Configuration page.
You will see it in the top.
Nov 18, 2016 | Ricoh SP C430DN Laser Printer
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
Disable color management
1. Find what you want to print and push print.
2. On the Print page, go to "printer options"
3. Choose to "Black Ink" in the options.
4. This might have to be done every time you print to ensure the colors are not being used every time you print.
Hope this helps----
Jun 19, 2014 | Ricoh SP C430DN Laser Printer
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Cyan is out of ink and i want to print in only black and white
Susanne,
Unfortunately almost all of the color lasers,except a few new Canon's,use the colors to make black.
That way they can inflate how many B&W pages you can get from the blck unit.
Sorry
Feb 12, 2014 | Ricoh Aficio™ SP-C210SF Printer
Aficio SP C411DN does not print cyan
Well, since you've tried everything, my recommendation is to try to clean the contacts with dry cloth in the left or right side inside the printer where the cartridges place in. see the result
Feb 01, 2014 | Ricoh Aficio SP C411DN Laser Printer
Horizontal black lines on print jobs Ricoh SP C430DN
Are theses along the border? You may need to replace the Black Drum unit
Dec 20, 2013 | Ricoh SP C430DN Laser Printer
TURN OFF COLOR PRINTING
Go to your printer properties, tick the GRAYSCALE Printing or find the option where you can choose the BLACK ink to print only.
Sep 06, 2012 | Ricoh SP C430DN Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
