Question about Measuring Tools & Sensors
How do i change the time onweather station 689r05
Model no 689r05
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
How to set time and date
We're not the psychic hotline! Model number?
Click on the link, it's La Crosse Tech weather stations. Find your model or one similar to yours. Mouse over and click "more info". Select the "support" tab and then product manual. How to set date and time will be in the manual.
Weather Stations Weather Browse Products
Aug 15, 2016 | La Crosse Technology La Crosse Wireless...
Changed the batteries in both the transmitter and weather station. It doesn't show temperature on the transmitter or show temperature and humidity on weather station
In some of these weather stations, you have to install the batteries in the transmitter first and then the weather station within a certain time limit. Also, the weather station must be within a specified distance from the transmitter when replacing the batteries.
If you look on the weather station, there should be a make and model number. If you have that, you can visit the website (if there is one) and download an instruction booklet for your model.
Jul 21, 2015 | Measuring Tools & Sensors
Changed batt now how to set time
https://www.sharpusa.com/CustomerSupport/ProductDownloads
Find and download you manual for the instructions
Jun 29, 2014 | Sharp Weather Station Atomic Clock
Need a manual for model cs1203 craig weather station
To change the time, press the time button. When it goes to 2000, you will see the date flashing. Adjust using up and down buttons. Then press the time button again. You can then use the up and down buttons to adjust the time. Finally, to toggle between F and C, use the up button by itself. To adjust between 24 and 12 hour clocks, press the down button.
Jun 10, 2012 | Measuring Tools & Sensors
I have lost the manual for marks and spencer weather station 689R05
help how do i change the clock or is there a mannul for it thanks
Dec 17, 2011 | Measuring Tools & Sensors
I just got an Orbit 4 Station Sprinkler Timer with Easy Dial from the landscaper who did my sprinkler system a week ago, he set the timing at 6:30 AM I changed it to 5:45 and SET it and now its running...
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Aug 26, 2011 | Garden
Setting the time zone
I actually have the same problem with an older model Brookstone weather station with remote temperature gauge. The time/date settings do not allow you to set time zone and eventually the clock syncs to PST.... ANY HELP HERE?
Mar 19, 2009 | First Alert FWS-101 Wireless RF Weather...
Measuring Tools & Sensors Logo
98 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
