Question about Eaton Powerware 9135 UPS (700465446) UPS System
Not able to shutdown the ups even the powerknob is pressed for 3 seconds and more
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Disconnect your batteries first. Then turn off
Posted on Mar 02, 2015
How to restart mobile
Press and hold the power button of your mobile for 3-4 seconds and release. Slide down if it asks you for shutdown
Let it completely shutdown and after that press and hold the power button for 2-3 seconds and release then it will be restarted
Nov 20, 2015 | Cell Phones
Tip
TomTom GPS battery discharge when off
With the TomTom GPS units, if you use it infrequently, you may often find the unit has a dead battery when you go to use it.
This is because turning the Tom Tom off normally with the power button doesn't actually turn it off fully, but instead puts it in a standby mode.
Even though the screen is off and it appears to be shut down, it's still using some power to maintain configuration settings.
If you know you won't be using it for a long period of time, you can press the reset button on the bottom of the unit (this can be done while it's off), and it should put it in shutdown mode, where the battery will not be drained so rapidly. If you do this, you can confirm it's in the shutdown mode by tapping the on button. This normally will power up the Tom Tom, but in the shutdown mode, it will not do anything. To wake it up from the shutdown mode, press and hold the power button for a few seconds, at which point it should turn on and greet you with the Tom Tom drums. It takes quite a while to boot up from this mode, which is probably why they defaulted to the suspend mode instead of a true "OFF" state.
For some of the newer units, they've omitted the reset button, so the process is a little different. Instead of pressing the reset button, do the following:
with the unit on, press and hold the power button. The shutdown screen should appear, but continue holding down the power button for another 12 seconds after the screen turns off. Timing is a bit touchy, because if you hold it too long, it'll end up just rebooting, and then you'll have to try again.
If you're successful in the shutdown, you can test it by briefly pressing the power button. It shouldn't turn back on with just a short press. If it comes on with the tap on the power button, you'll have to try again.
This whole process is a bit of a hassle, and extends the turn on time greatly, so you'll want to plan ahead when doing this, and just shut off normally if you expect you'll be using it within a couple days. However, the long boot up is preferable to having a completely dead unit when you need it, especially if you're away from a power plug...
on Jun 30, 2010 | GPS
Tip
Here's how to create a shutdown shortcut on your desktop
Instead of going to the start menu, choosing shutdown, then waiting for the computer to shut all the programs down, you can create a shortcut on the desktop to do it quickly. You can create a shutdown, restart, or a logoff icon on your desktop which will work a lot quicker than using the usual buttons in the start menu.
1. Go to your blank desktop
2. Right click on a blank space and a menu will appear
3. Choose New from the menu
4. Then choose Shortcut
5. Where it says type the location of the item type in shutdown.exe -s
6. Then press next
7. Now enter a name for your icon. Mine is called SHUTDOWN NOW
8. Press next
9. The Shutdown shortcut will be on your desktop
Different combination you can type in when creating a shortcut to shutdown, restart, or logoff.
Shutdown.exe -s
Shutsdown your computer in 30 seconds and will close all programs and ask you to save all work.
shutdown.exe -r
Restarts your computer in 30 seconds.
shutdown.exe -l
This one will logoff your computer back to the welcome screen where you will need to login again.
shutdown.exe -s -t 1
Shutsdown your computer in one second. the -t 1 tells it how long to wait. (one second in this case) You can put -t 10 or even -t 1120.
shutdown.exe -s -t 15 -c "Goodbye you idiot"
This is my favorite code. It will shutdown in 15 seconds and have a message in the box saying "Goodbye you idiot"
The -c "bla bla bla" stands for a comment.
Notes:
* to stop the computer from shutting down type shutdown /a into the run box located in the start menu..
* -f will force everything to close immediately without asking to save anything.
on Jan 29, 2010 | Computers & Internet
How to shutdown photocopy ir3025
The proper way to shutdown the machine is to press and hold the Power button in Control Panel for 3 seconds and wait for the shutdown instruction displayed. And turn off the main power switch located at the lower right side portion of the machine.
Jan 09, 2014 | Canon ImageRunner 3025 Black and White...
Please clear cmos if system no display after overclocking
Click the following picture to enlarge:
CPU Overheated
If the system shutdown automatically after power on system for seconds, that means the CPU protection function has been activated. When the CPU is over heated, the motherboard will shutdown automatically to avoid a damage of the CPU, and the system may not power on again.
In this case, please double check:
1. The CPU cooler surface is placed evenly with the CPU surface.
2. CPU fan is rotated normally.
3. CPU fan speed is fulfilling with the CPU speed.
After confirmed, please follow steps below to relief the CPU protection function.
1. Remove the power cord from power supply for seconds.
2. Wait for seconds.
3. Plug in the power cord and boot up the system.
Or you can:
1. Clear the CMOS data.
3. Power on the system again.
If after clearing the CMOS you still have no display, you may have damaged your motherboard, CPU, or RAM. If you need further assistance with this Motherboard, let me know.
Mar 25, 2011 | Biostar G31-M7 TE Motherboard
Improper Shutdown Message
1. Disconnect the power cord from back of printer ( while printer is powered on )
2. wait for 10 seconds
3. hold and press the Power button and connect the Power Cord.
4. Release the Power button after 3 seconds
5. Follow the Instructions on the printer screen.
Later try to shutdown it, it should not give the message again
Jun 16, 2010 | HP Photosmart C6180 All-In-One InkJet...
Laptop got stuck!
You can end the Not Responding Application to task manager, just press ctrl+alt+del then click on task manager, or ctrl+shift+esc to go there directly, click on task that is not responding then click on End Task.
If you want to shutdown your computer that froze just press on the power button of your computer for 10 seconds or more to force it to shutdown.
Dec 17, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
My x50z asus laptop wouldnot start when i press on/off push button unless after tens of start presses .now i Hibernated my laptop but still start button don't work.so to have my laptop operate i had to use...
did you check the switch if can do a shutdown process after you press the power button for 2 or 3 seconds? If not there's a problem with the switch...but if it shutdowns ok then I suggest have the OS re-installed to isolate the problem. You can use a separate HDD to do a disk recovery install. At the same time you can make the original disk as your backup.
Aug 16, 2009 | Computers & Internet
My ws-55315
Good Day afsho;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C.
good luck, big irish.
Jun 14, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Bliking light
The problem is waste tank counter alert.
I have the same problem, we need to make the waste tank counter reset, but I have tried it with no success.
mguahy
Mar 13, 2008 | Canon BJC S300 InkJet Printer
Eaton Powerware 9135 UPS (700465446) UPS System Logo
122 people viewed this question
Top Eaton Computers & Internet Experts
Lawrence Oravetz
Vuk B
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
