Question about Westward 5NUE4 Air Operated Grease Pump 28-3/4 In Tube
5nue4 westward air grease pump - Westward 5NUE4 Air Operated Grease Pump 28-3/4 In Tube
Lincoln model 82050 grease pump doesnt shut off
The valve that controls the grease or the valve that controls the air(?).. one is stuck.. the air valve can stick and cause too much PSI and the grease valve cannot overcome the pressure to allow it to close.
Sep 07, 2017 | Lincoln Air Tools & Compressors
How can I get to view an owners Manual for a westward drill press
try a search thru Google and see if there is one your can download
Aug 03, 2016 | Westward Drills
Westward 5.5 hp air compressor only runs on choke
remove carburetor, remove float bowl, carefully clean clogged fuel passages with carb cleaner, replace.
Sep 25, 2014 | Air Tools & Compressors
Air compressor
isn't one but the owners manual might have some simple trouble shooting info in the back
Nov 13, 2013 | Westward Air Tools & Compressors
My air compressor will fill up with out a problem when it is empty but once it runs down and tries to kick back on the motor will not turn over. please help
Sounds like the tank check valve is bad. recommend replacing the check valve located at the end of the air discharge line and tank.
Aug 10, 2011 | Westward 4B220 Portable Air Compressor
We havve a Westward 1YAY9 1500W inverter which has worked well for a long time. Now it often stops working after 5 minutes and after it has been shut off for a time, will start again. The pump we run is...
It is overheating. A good test for this is to use a soft gel pack that can be put in the freezer. Use and old towel to wrap the ice pack once and set it on top of the inverter for about 20 minutes. Then use the pump. If it runs longer, the inverter is going bad, and will cost more to repair than to replace. Check all wiring for green corrosion as this can also cause overheating, but the fact that you have the same power draw leads me to a bad inverter. 6.5 amps is pushing a 1500 watt pretty hard, try stepping up to a 2000-3000w Westward.
Mar 14, 2011 | Inverter Power ,1500W, WESTWARD, 1YAY9
When I reload the Greasegun, it won't pump grease! Doesn't matter if it is an Air Operated Greasegun or a Pump Style! What is the secret to getting out the Air Pockets??????
might try and bleed it like brakes.... take the hose off and put your finger over the hole. pump until you only get grease... just a thought, there is a valve in the end of the hose for clamping onto the zerk fitting... mightnot be enough pressure building up to let the air run through...
Just a thought....
Mar 02, 2010 | Lincoln Air Operated Grease Gun
I need the westward 3 unlock code
that is illegal, just download a key gen
Jun 14, 2009 | HP Computers & Internet
Westward 5NUE4 Air Operated Grease Pump 28-3/4 In Tube Logo
Top Westward Plumbing Experts
Donni Steen
Tom Chichester
Are you a Westward Plumbing Expert? Answer questions, earn points and help others
