Circuit diagram of DEFY Automaid 600 model DAW322
The machine is not operating but the supply power is ok only the front panel start pause light is blinking
  • 291 Answers
SOURCE: defy automaid instruction manual how to use
click the link below for defy automaid manuals and instructions guide:
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
thanks and plse do not forget to accept the solution.
Posted on Apr 03, 2009
SOURCE: defy automaid won't spin
Put the machine on its side and check the wires to the pump. i found one of the wires broke off the lug on the pump side. Could be from all the vibration from the drum. The machine will only spin if the drainage is working.
Good luck.
Posted on May 11, 2009
localwonder
  • 6784 Answers
SOURCE: My Defy Automaid 600 does not run water in. Tap is
HI. this is a failed inlet water valve assembly. you will need to replace this assembly asap if possible.
Posted on Jun 11, 2009
localwonder
  • 6784 Answers
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Posted on Jun 21, 2009
SOURCE: WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
Diagram of internal wiring of ariston AV41washing machine
Posted on Mar 20, 2011
My defy automaid 600 front load washing machines barrel seems to be loose and is knocking against something. How to I inspect it to see what is wrong.
Hi, it could be a few things either drum bearings are needing renewed or drum tension / shocker is not functioning properly.
Jan 25, 2016 | Washing Machines
Why would my Defy 600 Automaid drum stop spinning?
The pressure sensor might be faulty. Something is telling the control that it is too full of water so the pump starts to empty it to avoid flooding. This is usually the water level or pressure switch.
See manual for your unit at this site.
Pre
Sep 05, 2014 | Washing Machines
My DEFY Automaid 600 does not heat the water
It is possible that the thermostat may be causing a problem if it is faulty. It might be sending wrong signal to controller confusing it to think water temperature is already reached and shut off the heater.
The thermostat may look like this part.
http://www.macspares.co.za/laundry/thermostat-defy-automaid-std-models?cPath=1_195_175&
Apr 25, 2014 | Washing Machines
Hi, I own a Defy Automaid 600 and when I run a
Hello
Remove the detergent tray and look in to the top were the tray goes in there is a water dispenser there with a lot of hole check that non of those holes are not blocked, if so use a tooth brush to clean the holes.
Thanks
Jun 15, 2011 | General Washing Machines
Our defy automaid 600 daw 322, will wash, but will not spin or rinse
My Defy Automaid 600 spin and drain without washing but only drain and do not spin with washing in (i have put only 1 t-shirt in - and still don't spin)
Jan 23, 2011 | Washing Machines
Defy automaid instruction manual how to use
Apr 03, 2009 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
