Question about Pride Health & Beauty
Continuous beeping - Pride Health & Beauty
Continuous beeping
You have a faulty key on the keyboard. Replace the keyboard, they are not expensive. Look at ebay for prices.
Feb 06, 2014 | Computers & Internet
Computer won't start at all - continuous long beeps
One long beep probably indicates that the memory chip(s) are not inserted properly.
Jan 19, 2014 | Acer Aspire E700 PC Desktop
ADL348 is constantly beeping and does not complete cycle
If it beeps continuous and starts on the rinse cycle,then this is indicating the control board is bad and needs to be replaced. NOT THE TOUCH PAD, but the control board.
Dec 17, 2013 | Dishwashers
Gateway laptop wont turn on just beeps continue
How Many Beeps you hear ?
1 Beep Continues > Problem in RAM
2 Beep Continues > Problem in RAM or Mother Board
3 Beep Continues > Problem in Base of RAM is Not Same
4 Beep Continues > Problem in Time System
etc.
i Recomended to you to see at zylone81.indonesianforum.net/forum/ for to know Computer and laptop Problem from Beep sound.
Jan 06, 2012 | Gateway NV5929u PC Notebook
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
My computer cannot boot because of long beep
beep code usually means a basic function was unable to start. A basic function might be reading memory, displaying video, or being able to send information to a hard drive. The most common problems that cause beep codes are memory and heat-related failures caused by a build-up of dust in critical cooling areas. Use the beep code tables in this document to help find what hardware component is causing the problem. This might reduce the time required to find the hardware component that needs adjusted, reseated, or replaced. WARNING: HP recommends that these steps be performed only by someone with experience in working on computer hardware. Incorrectly handling sensitive internal components can further damage the computer and can introduce the risk of personal injury. Using the correct environment for working on computers (ESD precautions and tools), use the following steps to isolate and fix the problem:
  1. Turn on the computer.
  2. Listen to the beep code and write it down. Write down the number of beeps before each pause, if the beeps are long, short, high in tone, or low in tone. You can use the other sections in this document to look up the beep code description. The beep code and its description can be used for further Internet research if needed.
  3. Note which fans are spinning, not spinning, or making strange noises. It might be possible to prevent the beep code by setting the fan speed to a higher setting in the BIOS setup utility or by cleaning the cooling fins and vents.
  5. Check the case fan and power cable.
    1. Turn off the computer by holding the power button for five seconds.
    2. Disconnect the power cord and then disconnect all external cords from the computer.
    3. Remove the side panel to open the computer.
    4. If the case fan was not spinning, make sure the case fan power cable is connected to the correct pins on the motherboard. Replace the fan if it was making excessive noise or was not spinning. If you had to plug in or replace the fan, replace the side panel, plug in the power cord and turn on the computer. If the beeps continue, continue to the next step.
  6. Disconnect the power cord and remove the side panel and perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
    1. Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
    2. Remove a memory module. If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module. Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
    3. If the computer has a graphics adapter, remove it. If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step. If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
    4. Remove a PCI card. If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card. Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
    5. Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
    6. At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly. Otherwise, have the computer serviced by HP or by a qualified service center.
Jul 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
3 beeps
Please Try this :-
:- Perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and ()listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
Remove a PCI card.
May 12, 2009 | Intel Motherboard
Continuous beep
This is most likely a memory error. You didn't say if you've done any work inside the computer but if you have double check that the ram is seated correctly.
You bios is award and these are the beep codes:
Beep code brief:
1 Long Beep: Memory problem
1 Long Beep and 2 Short Beeps: Video error
Continuous Beeping: Memory or video problem
Any other beep pattern: Most likely Memory problem
1 long Beep: Memory problem
Something is wrong with the memory installed. Check out the troubleshooting memory problems FAQ for details. Note that there could also be something wrong with just accessing the memory (ie the motherboard has a problem).
1 long beep, then 2 Short Beeps: Video error
The motherboard is not able to access the video card for some reason. Either the video card is not working, it's memory is not accessable, or it's BIOS may be corrupt. This error code could also mean something is wrong with the motherboard.
This is a tricky situation... likely the problem is either memory or the video. This can also be found when the motherboard is faulty.
Apr 30, 2009 | AOpen MX3L (91.88110.251) Motherboard
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Health & Beauty Logo
12 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
