Kaycera FS-5150 dn error code 7401 - Office Equipment & Supplies
  • 48 Answers
Hi there, the error code 7401 means that there is a problem with the toner sensor in the black developer unit (see service manual page 1-4-15), replace the black developer unit and the problem will be solved.
Posted on Jan 19, 2015
4 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: KYOCERA ECOSYS FS-C5100 DN PRINTER. WHEN I TURN IT
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Posted on Sep 26, 2011
SOURCE: error code C70000
Hello, the code 7000 refers to the toner motor, but if you check my blog and there I have the full service manual. I hope you let me serve a Comment
http://tiototos.blogspot.com/ press click
Posted on Oct 15, 2011
reinhold_eic
SOURCE: Kyocera FS-2000 dn error 7410-0001163 What is the problem ?
Call Sevice 4710 means the Connection between fhe Drum-Kit DK310 and the DV 310 is broken.
Open the Door on the left side, and push the Drum DK310 into the printer, so you here a klick,
Power off the printer and then power on the printer.
The Call 7410 Message is away, the Numbers after 7410 are the pages of printing
Posted on Nov 30, 2012
What does a c4203 code mean?
More than likely you have a PDF Owner's manual on the Software install disk. It should have troubleshooting section to help you with this and any future issue. The software may also have a trouble shooting system.
I googled and this seems to be a possible answer:
http://northeastprintsupplies.com/images/FS-C5350DNENSMR1.pdf
May 14, 2015 | Kyocera Mita Ecosys FS-C5350DN - 32PPM...
Kyocera 1020 error codes list
Hi Pandirayaj,
I have this manual for you to see errors in Kyocera FS-1020D. Hope it helps.
Kyocera FS FS 1020D Operation Manual Page 37 Error Messages
Apr 25, 2014 | Kyocera Mita FS-1020D Laser Printer
Fs5350dn wrinkles envelopes when using the envelope switch button
Hi, I am having a serious challenge printing to the FS-5350-DN from work or anything, it simply just restart the application and reopen the document. It used to work just fine, but all of a sudden this starts to happen. this is from a select number of computers though, both windows XP and WIndows 7, but funny enough I can print to another FS-5350-dn on the same network from other computers to the same printers. These printers are all on one Printer server, we are also using papercut...
Can someone say what is going on here?
Oct 08, 2012 | Office Equipment & Supplies
Oct 04, 2012 | Kyocera FS-2000D Laser Printer
I HAVE A KYOCERA ECOSYS FS-4000 DN PRINTER. WHEN I TURN IT ON, I GET AN ERROR MESSAGE STATING "CALL SERVICE 0150:0003704". WHAT DOES THIS MEAN AND HOW DO I FIX THE PROBLEM?
The error indicates -
Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Causes - Improper installation engine PWB EEPROM. Check the engine PWB EEPROM installation,
- Defective engine PWB. Replace the engine PWB
IF turning the printer off and unplugging then plugging back in and turning back on doesn't correct the problem I would suggest you contact an authorized Kyocera service center such as www.gfbm.net.
Jan 24, 2011 | Kyocera FS-4000DN Laser Printer
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Error code C70000
Mar 16, 2010 | Kyocera FS-4000DN Laser Printer
Call for service error 7410:0112053 on Kyocera FS3900 DN
most likely the drum popped out.
open the left side cover and remove the waste toner bottle..seated just above the waste toner bottle..press on the drum unit that sits above it..you will here it pop back into place .. if you hear it snap back it simply power off than back on printer....
if the drum is seated correctly.. than you need to replace the drum unit
Jan 12, 2010 | Kyocera FS-2000D Laser Printer
My Lexmark X 5150 keeps showing error 0502. What does this mean?
on a lexmark x 5150 error code means ink cart. We were out of ink.
Oct 02, 2009 | HP DeskJet 5150 InkJet Printer
233 people viewed this question
k24674
