Question about Nokia 5310 Cellular Phone
How to reset dtv5
Can't do the reset 1234. how can i fix it?
What is this error dns_probe_finished_no_internet and how can i fix it
It has tried to find the internet connection and failed.
Look at you internet cable and whether the cable modem etc. is working.
Mar 18, 2015 | Computers & Internet
My samsung sch-r710 touch screen is unresponsive. Will a hard reset fix the problem? How do I perform a hard reset?
try to calibrate the touch sensitivity setting before you reset it this always work in any case.nno need to to do a hard reset
Aug 14, 2012 | Samsung Lands Phones
My phone has been doing abnormal reset about ten times a day and it asks me to send report to HTC and I do but haven't fix it
Have you tried a hard reset? Google your phone type and hard reset and follow the directions, it does delete ALL of your information. That happened to my Droid Incredible and a hard reset fixed the problem for me.
Jun 03, 2012 | AT&T Lands Phones
My folks (elderly) have a Lucent AS40/AT&T 1715 which for reasons unknown is displaying "F1" and beeping. What is the fix?
I will advice you try to reset the device, once the device is reset, the problem should be fix, just reset the device to fix the problem.
Take care.
Aug 24, 2010 | Lands Phones
Blackberry 7130e. It is showing that it has a signal but i cannot recieve or make any phone calls or texts. It has an arrow flashing at the top by the signal like its sending somthing constantly...how do i...
This problem happens on pretty much any computer-related device. Something happens and you can send anything. It’s annoying, but there are actually two ways to fix it. You can perform a soft reset, which is done by pressing the ALT + CAP + DELETE keys on your handheld at the same time. If this doesn’t work, perform a hard reset. This is done by finding the RESET button at the back of the handheld. Sometimes, this button might be near the bottom, under the battery cover. Press the RESET button using a pin or paper clip. With either method, you shouldn’t lose any data.
Perhaps, is you did not see the reset button,you can also do the hard reset this way, in the process of powering your phone, pull out the battery straight before it finish loading, this helps fix abnormality on the blackberry phone.
Take care.
Jun 05, 2010 | RIM Blackberry 7130e Smartphone
What is the specific drive-time to reset the computer on my 97 Ford Aspire? I disconnected (and reconnected) the battery and now it won't pass inspection because the computer hasn't reset.
what were the codes? It may never reset until u fix it. Most codes aren't intermitten. Not more than 80 miles if doesn't reset then you need to fix problem.
Feb 06, 2010 | 1997 Ford Aspire
BRAKE LIGHT ANS ABS LIGHT SERCIVE HOW TO RESET IT
need to have scanned to fix the problem some auto stores such as auto barn / advanced auto scan for free the trouble code will give u a start point towards fixing ur problem-- reset when problem fixed or have auto store reset after scan but will most likely return
Jan 31, 2010 | 2001 BMW 325
Ok want to see if i can fix this before i call in the big guns. xerox XD series have a code of flashing 00 then H then 4 powered system down and still the same what is it and what can i do to fix it?
You can fix this. Usually this is a false fuser code. I have a tip posted on this site to reset the code. Just look at the tips and search for Sharp AL series H4 code reset. Your Xerox XD series copier is made by Sharp and was a Sharp AL series copier. The reset procedure is the same.
If the reset fixes the problem please leave feedback for me.
Thanks
Jan 08, 2010 | Office Equipment & Supplies
My camers keeps on asking me to "press the reset switch" and reseting does not seems to fix any problem for me.
I found the fix. It's so easy.
Take out the battery
When it says hit the reset button, hit the reset button.
Turn the camera to off
Wait 2 minutes
Put the battery back in.
Turn on the camera. It won't say reset anymore.
Jun 30, 2009 | Panasonic Palmcorder PV-GS9 Mini DV...
Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Nov 14, 2007 | Siemens Gigaset 2420 Phone
Nokia 5310 Cellular Phone Logo
138 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
