Question about ASUS Eee Computers & Internet
Half the screen is white, half the screen is colorful
I have an ASUS G73JH laptop that has incurred something I haven't seen before. The left half of the screen is white with horizontal lines jumping around. The right of the screen is a mix of colors. It kind of looks like a tie-dyed t-shirt. On the color side, I can make out the desktop there. On the white half I cannot see the desktop. My cursor is operational but I cannot see it on the white, left side. Anything I can open (like BIOS) is half blocked out by the white, left side. I'm sure it's a coincidence, but I did use compressed air a few hours (8) earlier to clean out the laptop. Any ideas would be greatly appreciated!
    Top Expert:
  • ASUS Master
  • 25,352 Answers
I would try using an external display. That will prove the GPU. If it is OK then the display is faulty, if not the GPU is faulty.
Posted on Nov 20, 2013
  • 69 Answers
SOURCE: A horizontal line on the screen Dell studio 1558
seems like your screen have some dead pixels. the only solution is replacing the screen. ita a hardware problem not software.
Posted on Aug 28, 2012
  • 163 Answers
SOURCE: laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Posted on Feb 06, 2008
cheap to fix
  • 404 Answers
SOURCE: Laptop Screen Has Different color lines
screen fault, needs new one but if it doesn't happen to an external one.
hook up a normal pc screen to the side vga and see if the same is there, if the same then it's possibly the refresh rate is too high or a motherboard issue
Posted on Mar 02, 2009
SOURCE: Dell Inspiron 1501 screen half black
Had the same problem. Fixed it though. Here's how:
You'll notice that the screen comes back to life if you press down on the very top of the green line. This is because a controller circuit board behind the LCD screen (at the top) is pressure fit flat-surface-to-flat surface to the contacts on the back of the LCD. Eventually, the sticky substance that holds this circuit board in place wears thin, collects dust, etc.. and the connection between the circuit board and the lcd contact is lost. The line appears where this break in contact has occured.
So, the solution is to increase the pressure at that point to reestablish the connection. I wasn't able to remove the circuit board to clean beneath it as it seemed too likely to cause damage. Nor would I have had the right adhesive to connect it back, so I simply removed the LCD and put a bunch of tape at that point so that it would "push" with a little more pressure when screwed back into place. Worked great.
To remove the LCD, pull off the 6 feet around the screen. Remove the screws behind them. Carefully pry off bezel with a small flathead screwdriver working your way around it. Once removed there are simply 4 screws on the left and 4 more on the right of the LCD to remove. Pull out screen carefully and start stacking bits of tape on the spot where pressure seems to work best. Put it back in and see if you've made any difference. I did this with the computer on so I could verify my results. Just be careful not to short out any naked contacts.
If this doesn't work for you, at least you'll know you just need to replace the LCD, not the video card. Easily found on ebay.
Posted on Mar 12, 2009
ssebata paul
  • 159 Answers
SOURCE: line across screen
scane for virus and reinstall the operating system
Posted on May 30, 2009
Replacement lcd screen not working on g73jh
I would check and make sure that the replacement screen is fully connected. It may have come loose when reassembling. Make sure everything that you removed and unplugged is replaced.
Aug 14, 2013 | ASUS Computers & Internet
Asus g73jh status indicator for battery flashing green/orange
the green and yellow light indicating that your battery needs replaced
Feb 02, 2013 | ASUS G73JHA1 Notebook
My asus g73jh has no sound and all usb port not recognized. I reinstalled everything(win 7, bios update, driver,...) but still don't work
For the sound, try going to
Control Panel > Sound > Playback
or
Control Panel > Hardware and Sound > Manage Playback Devices
and right-click speakers and select "Set as Default Device"
Jun 18, 2012 | ASUS G73JHA1 Notebook
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
Where can i find a battery for this laptop?
Here's a link where you can get it http://www.battery-notebook.co.uk/asus-G73JH-A1-battery-1739b.htm
Please click YES if this helped you out. Thank you for choosing FixYa! Have a great one!
Sep 13, 2011 | ASUS G73JHA1 Notebook
I cannot get my internal microphone to work on my asus g73jh thanks
I'm having the same problem, some gaming laptop you are. I have a love and hate relationship with my asus g73jh. Theres more fixing and less playing IMO. Somebody please help us.
Aug 01, 2011 | ASUS G73JH-X5 PC Notebook
My asus g73jh backlight will not turn on, it only turns on during reboot. How can i get it to turn on
If you're having trouble with the keyboard lights, hold the Fn key (right next to the left ctrl key) and press F4 to get the keyboard turned on. There is also the button at the top left corner that turns lights off.
Sep 04, 2010 | ASUS Computers & Internet
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Computers & Internet Logo
180 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
