Gateway nv49c brightness settings problem
I cant change my brightness setting...the fn+up/down or fn + f11/f12 doesnt work .....
  • ankit kamble
    ankit kamble Nov 21, 2013
    i've tried this...but the so called brightness level bar which u slide left n right to adjust the brightness is missing...
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 13 Answers
You can change the settings through your Control Panel.
Follow these steps.
For Windows Vista or 7.
Click on the start button then select control panel, then select Display, then select Adjust Brightness on the Left.
Save the changes after you have made them.
Posted on Nov 20, 2013
  • 239 Answers
SOURCE: Keys dont work.alternative way to change brightness?
Yes you can go into your display properties and look in the settings tab and look for advanced click that and open color tab or the overlay tab, color tab should get your brightness turned up, And if you can't see you can go into your bios and adjust your brightness from there and get it back to where you can see it if you can't write me back here so we can try another method. Ok I hope that helps you out somewhat, Oh yeah you can also hook up an external key board into your usb connections and you should be able to work everything from that too.
Posted on Jan 15, 2008
lumidee
  • 15 Answers
SOURCE: Solution
replace the keyboard
Posted on May 28, 2008
warlock61
  • 659 Answers
SOURCE: Problems changing the brightness
try using the fn key and the brightness keys at the top of keyboard
Posted on Nov 24, 2008
naslicer
  • 73 Answers
SOURCE: Fn +F2-F3-F4-F7-F11-F12 how do you use
dear bdgdag,
please visit the following site for more information about the functional keys.
remember to vote for me if its useful
http://www.aarp.org/learntech/computers/howto/a2003-03-28-functionkeys.html
Posted on Dec 19, 2008
  • 10 Answers
SOURCE: Hi,my laptop is Asus X42J,the
Hello there. Follow my steps:
  1. Go to support.asus.com
  2. Select "Download" (if you don't see a "Download" button due to being in another language, select the last item from the main menu and select "English)
  3. Find your laptop model using the wizard
  4. Select your operating system (to determine whether if it's a 32bit/64bit, go to your start menu > right click on "Computer" for Windows Vista/7 or "My computer" for Windows XP and look for a text which says "XX bit operating system)
  5. Go to the "ATK" tree
  6. Download the "ATK Hotkey Utility" thingy and install it.
Posted on Mar 16, 2011
Help with d2d recovery for gateway Lt 20 notebook
Try tapping the Del key. Also try F11, if neither of those work, then try these combos below:
Fn+F2
Fn+F8
Fn+F10
Fn+F11
Fn+F12
Shift+F2
Shift+F8
Shift+F10
Shift+F11
Shift+F12
Remember to hit these key combos before Vista loads, only when you sure the keys were pressed, cross it off the list on move on. When you do determine the correct key combo, please post back here, it will help others with the same question.
Oct 30, 2014 | Computers & Internet
Tip
How to use F1, F2 ?..Function buttons on Hp laptop.
For those who do not know how to use the F1, F2, F3..... buttons on HP laptops, here is an opportunity for you to know.
We see these buttons on most laptops but don't know what they are used for. F1, F2....... buttons are the first set of buttons on the keyboard. These buttons makes it easy for anyone to access some programs on the computer without using mouse.
Follow the below procedures on how to use some of these functions:
To put your HP laptop on sleep mode, Press and hold Fn button on your keyboard, (without leaving it) then press F5 (Fn + F4).
To lock your HP laptop, Press and hold, Fn button, then press F6 (Fn + F6).
To reduce the brightness of your HP laptop, press and hold Fn button, then press F7 (Fn + F7).
To increase the brightness of your HP laptop, Press and hold Fn button, then press F8 (Fn + F8).
To put your laptop on mute, Press and hold Fn button, then press F9 (Fn + F8).
To reduce the volume of your HP laptop, Press and hold Fn button, then press F11 (Fn + F11).
To increase the volume of your HP laptop, Press and hold Fn button, then press F12 (Fn + F12).
To shut down your laptop or to view other shut down options, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
To close any page on your HP laptop, Press and hold Alt button, then press F4 (Alt + F4). Note that this particular function can be used on all computers and laptops.
Good luck.
on Nov 06, 2010 | Computers & Internet
List each function key
o F2 boot to BIOS.
o F12 boot device menu.
0 Fn+F1 sleep/hibernate per power management setting.
o Fn+F2 battery charger ON/OFF.
o Fn+F3 DCP Power Manager Battery Status.
o Fn+F4 numlock ON/OFF for embedded Fn+numeric keypad.
o Fn_F5 scroll lock ON/OFF.
o Fn+F7 DCP.
o Fn+F8 display device.
o Fn+D display OFF/ON (conserve battery without shutting down entire system).
o Fn+Z reset fan temperature table and sensor.
o Fn+Right-Arrow keyboard illumination OFF/ON Auto ALS (lit upon input in dim lighting)/ON (lit upon input). Use DCP to set input device, brightness, and auto OFF delay.
o Fn+Left-Arrow display Ambient Light Sensor OFF/ON (brightness varies with ambient lighting).
o Fn+Up/Dn-Arrows override display brightness until boot to BIOS setting and/or power mananagement setting.
o Alt+Fn+F11 screen shot.
Jul 09, 2014 | Dell Latitude E6400 Notebook
Function keys
You need hold down the Blue (FN) key on the left and Press Up or Down.
It will not work on all laptops - some are shipped with screens that are not dimmable.
You can also access the Brightness functionality via the BIOS screen - when booting you will see Press (F2/F12/Del) to Enter Bios - press the key it suggests in time and you will enter BIOS settings - there is a page in there with a brightness slider.
I'd recommend you don't change anything else in here unless you know exactly what the setting does. make sure to Save and Exit. Not just Exit.
Dec 20, 2013 | Dell Studio 1737 Laptop
How do I use the F9, F10, F11 and F12 keys?
Some Gateway (desktop) computers do not have the dedicated F9, F10, F11 and F12 keys, but for a Gateway laptop, those four keys have dual functions for media control (which is the default use) or as Function keys. However, to use F-9 through F12 as Function keys, you must first press the Fn Key and then press the desired F-key. The Fn key is the second key to the right of the spacebar. To launch the Gateway Recovery process during start-up, you must press Alt+Fn+F10.
Aug 19, 2011 | Gateway Computers & Internet
What is the third lock light, I have a Cap Lock, a Numerical Lock. What is the third one?
I beleive it is the scroll light:
Fn+F1 Suspend switch
Fn+F2 WLAN switch
Fn+F3 Keyboard light down
Fn+F4 Keyboard light up
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT switch display
Fn+F9 TouchPad Lock
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Fn+Ins Numeric Key Pad on/off
Fn+Num Lk: Scroll Lock on/off
Fn+Del Scroll Lock on/off
Fn+Space Power 4Gear
Fn+C Splendid
Fn+V: Life Frame
Jun 20, 2011 | ASUS 90-A4C1K1000 Keyboard
I need to know what the keys f1-f12 keys usage.
The uses for the function (f1-f12) keys varies based on which program you have open at the time. Different programs use them for different things.
However, your computer also has some default uses for these keys when combined with pressing the fn (function) key.
fn + f1 locks computer
fn + f2 changes our power use profile
fn + f3 puts the computer to sleep
fn + f4 puts the computer into hibernation mode
fn + f5 changes the display/output mode
fn + f6 decreases the screen brightness
fn + f7 increases the screen brightness
fn + f8 enables/disables wireless connections
fn + f9 enables/disables the touch pad
fn + f10 turns the cursor overlay on/off
fn + f11 turns the numeric overlay on/off
fn + f12 turns scroll lock on/off
May 05, 2011 | Toshiba Satellite Pro L300 Notebook
I have a advent m201 laptop . how do i turn the built in webcam on please
Try this
Function Keys Fn+F1 - Places the computer into sleep mode
Fn+F2 - Changes the (I-Powerxross) power settings
Fn+F3 - Switches display modes: LCD only, External monitor only, LCD+External Monitor
Fn+F4 - Turns Wireless LAN on/off
Fn+F5 - Switches OSD (on screen display) on/off
Fn+F6 - Turns the Touchpad on/off
Fn+F7 - Turns the Webcam on/off
Fn+F8 - Mute Sound
Fn+F9 - Reduces speaker volume
Fn+F10 - Increases speaker volume
Fn+F11 - Reduces the screen brightness
Fn+F12 - Increases the screen brightness
Fn+Esc - Toggles Bluetooth & 3G on/off (optional)
Thanks
Dec 30, 2010 | HP Pavilion dv6000z Notebook
My hp elitebook 6930p display is very dim i tried the fn thing it didnt work how can i brighten the display
I had a similar problem--I had to disable the ambient light sensor to fix the problem: fn-f11. Now it's as bright as I need it to be.
Nov 02, 2010 | HP EliteBook 6930p Notebook PC
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Jun 15, 2010 | Toshiba 310CDT Keyboard
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
