Question about Saeco Vienna De Luxe Espresso Machine
Coffee beans will not grind
My wife thinks she may have spilled water in the coffee grinder. Now the grinder turns and the beans bounce around, but they are not being ground. No coffee grinds get created and dispensed and the machine times out. I have removed the hopper and vaccuumed the burr-grinder clean and still no change. what else can I do?
  • coffee hound Nov 27, 2007
    I have the same problem and am willing to do the cleaning. I can find the doser adjustment knob, but I'm not sure what the doser channel is. (I didn't spill water in my machine, but I have the same grinding problem. Perhaps it's the type of bean I used?)
    Problem Solver:
  • 8 Answers
If the grinder is blocked try changing the grinder setting up to the coarsest setting (I think it is numbered 16 on this model) and then vacuum or fill with beans and push them through. Be sure that any damp coffee has gone as you don't want the grinder blades to be left wet.
Never freeze or refrigerate your coffee beans as the condensation from doing this can also block your grinder. Also never use coffees that have been flavoured during the roasting process as they are often too sticky or oily and will block your grinder. These coffees should be ground using a grinder that can be easily pulled apart for cleaning...which is not the case in the Saeco automatic machines.
After you have finished clearing your grinder you will want to turn it back down to a finer setting ( a setting of 6 or 7 works well on this model) however you should only turn the grinder setting finer while the machine is actaully grinding. Otherwise you may find the coffee beans jam between the blades.
If you are unable to clear the blockage it might need to go to a technician.
Posted on Dec 09, 2007
    Sergeant:
  • Saeco Expert
  • 223 Answers
Your machine will probably need service. The water will cause damage to the grinder burrs.  I can send you instruction on how to clean out the grinder on a Vienna if you provide me will your email address. You can email me at [email protected].
You are not the first person to do this. These problems come in at least once a week.
Hope this helps.
Johnny
Posted on Oct 12, 2007
SOURCE:
Hi. I have a miele cva4060. The grinder is working but it does not seem to be getting any beans through it and I am only getting water dispensed instead of a coffee shot! It was working fine a few days...
Hi
If you hear its 'grinding' then that's good - problem is where is the ground coffee going or supposed to go??
Check there is no build up of damp/dried coffee grinds in the pathway between grinder and brew unit - this can happen if the machine is not properly cleaned say every 3 mths or more often depending on usage - coffee 'dust' can build up.
Also suggest remove all beans from grinder, vacumn last ones out. clean all around grinder opening. Add a dozen or so beans to the grinder, turn on and try again. If the beans disappear, its grinding properly. If they don't end up in the brew unit, then the hold up is as I said in that pathway - grinder to brew unit. If you cant see an obvious blockage/build up, suggest you have a tech look at it.
Cheers
Mike
Dec 10, 2017 | Miele Coffee System
Blade turns slowly and will not grind.
1. This fixes almost all the "beans will not feed or beans will not grind" problems unless you need a factory part for repair.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind.
Nov 25, 2009 | Cuisinart Coffee Makers & Espresso...
Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Hello. grinder won't grind
HI
Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. This will be above where the brew unit was. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There are 2 knobs in the bean hopper. Turn the large knob to the largest number. You can turn the knob to a larger number any time but it has to be grinding to turn to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can turn the knob back to a number that was higher than the one you had it on, but only when the grinder is running.
Jul 24, 2009 | Gaggia Syncrony Espresso Machine
Beans won't grind
Try cleaning out the grinder with the instruction for this link: http://www.cerinicoffee.com/Saeco_technical_documents.asp
Polyglot, if you have done this already it sounds like there is something wrong with the grinder switch on your machine. You will have to get the machine serviced.
We service saeco espresso machines based out of New York.
Checkout our website for more information: www.CeriniCoffee.com
Youngie,
Your problem is not the same as Polyglot. Try cleaning out the grinder using the link above. It works 50% of the time. For some reason your machine is not grinding. Common reasons are water has been accidentally spilled in the bean hopper or the grinder just has a problem and needs to be addressed.
In the case where water spills into the bean hopper you may need to change the grinder burrs. (http://cerinicoffee.com/Grinder_burrs_saeco_gaggia.asp)
Hope this helps.
Apr 02, 2008 | Saeco Royal Professional Espresso Machine
Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Aug 21, 2007 | Cuisinart DGB-600 Coffee Maker
Coffee Grinder not working
the grinder is most likely stripped and needs to be replaced:-{
Jul 23, 2006 | Saeco Caffe Charisma Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
1,013 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
