Question about ASUS Computers & Internet
Esc key not working - ASUS Computers & Internet
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
Fn+esc not working
TRy fn then esc or ctrl or windows esc. Is it even loaded onto your computer? Does your function key work with other things?
Aug 24, 2014 | HP Pavilion g6-2210us 15.6" Notebook PC
Hp presario CQ62 esc key not working
its usually F2 or Delete button to access the bios, have try that
Feb 23, 2013 | HEWLETT-PACKARD HP Compaq Presario...
At turn on it say ( Press the esc key for startup menu ) when I press the esc key ( ESC...pause startup comes up...
When you turn on your computer, you do NOT have to enter the startup menu. Do not press any keys when it asks you to press the Esc key. Once that screen goes away, it will take a minute for Windows to boot up and your good to go.
Thanks for using FixYa.
Aug 27, 2011 | HP Computers & Internet
Fn (function) key not working in my new hp elitebook 8440p laptop. It is running windows XP SP3.
A good check of whether the Fn key is working is to display the system information as follows...
1. briefly press Fn key, and then briefly press the Esc key
or alternatively...
2. Press and hold down the Fn key, briefly press the Esc key, and then release both at the same time.
This should display the version of the system BIOS as the BIOS date or system ROM version number.
If this doesn't happen, then either one or both Fn and Esc keys are not working. In any case since your laptop is new, it should be covered by a 30-day exchange policy from the place of purchase and you should just take it back for an exchange. If you can't get it exchanged and the purchase was on your credit card, you should have purchase coverage from the credit card company as well.
Mar 22, 2011 | HEWLETT-PACKARD HP EliteBook Notebook
On the bottom, it shows <esc=boot menu> <f1=setup> <f10=system recovery> but it doesn't respond to anything or move from this screen
Check that your keyboard is connected, and is working properly.
Try your keyboard on a different computer.
Try a different keyboard on your computer.
The 'ESC' key should always work.
The 'F1' key should always work.
If your disk-drive is *NOT* "dead", then the 'F10' key should work.
If neither 'ESC' nor 'F1' work, you have a serious problem with the motherboard.
Feb 03, 2011 | HP Compaq Presario SR1850NX (ER925AA) PC...
I have an asus 1000he netbook and haveing boot problems what is the boot menu key?
ESC (Escape) on the keyboard should be the Boot Menu key, means you have to tap the ESC key once you press the power button to switch on the Machine and select the boot device from the options available.
If ESC key doesn't work, then try F2 or F8 or F12 (these are all the boot menu keys for Asus motherboards and Laptops).
Let me know if you need further help, but with more details about your problem.
Good Luck.
Thanks.
Dec 17, 2010 | Computers & Internet
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite A105-s2716 power-up password
Hi, usually to get into bios on a toshiba laptop you press and hold the Esc key or the F1 key. try both of these, if they dont work, try this: 1. Turn on computer by Holding down power button while pressing the ESC key. The machine will beep, then display: Check System, then press [F1] key. 2. Release ESC key 3. Press F1 key If none of these work, we may have a different problem all together, get back to me if so, and i will see if we can find a solution. Hope this helps! Si :)
Sep 26, 2007 | ASI CL51-15 Notebook
Computers & Internet Logo
16 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
