Question about Epiphone Les Paul Studio Electric Guitar
Burns wiring diagram - Epiphone Les Paul Studio Electric Guitar
Electric guitar wiring diagrams
www.seymourduncan.com is a professional resource that offers diagrams of nearly every electric possibility (# of volume and tone knobs, switch types, and pickup types). There are others sites, but SD is the most complete.
Sep 03, 2014 | Music
Wiring burns bass vista sonic
Could you please be more specific? I'm not sure if you're looking for a wiring diagram (if so, I have one posted below), or if you're having a problem with grounding or other wiring issues.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=passive_soapbar
The above link is a wiring diagram for bass guitars that closely match the one you are asking about.
Hope that helps!
Oct 21, 2013 | Epiphone Les Paul Studio Electric Guitar
Need adiagram for replacing 3 wire factory humbuckers with 4 wire seymour duncans
These are for the seymour duncan JB pickup which uses an extra switch for a coil tap. If you tie the leads of the switch you can avoid using it in which it would become a normal humbucker.3_8_2013_7_29_41_pm.jpg
Sep 26, 2011 | Music
Wiring
Here are links to a standard LP wiring diagram and a LP Jr. wiring diagram. Absolutley free at stewmac.com
http://www.stewmac.com/freeinfo/Electronics/Wiring_diagrams/i-1217.html
Jun 17, 2010 | Epiphone Les Paul Studio Electric Guitar
Im looking for a curcuit diagram for the switchmode power supply in my Behringer PMP3000.
If the supply failed I can tell you which parts to replace... and if it failed there may be a failure in the power amp that caused it. You can contact be directely at fredy2 @ aol.com... put Behringer in the subject.
The supply when it fails takes out eleven components including two expensive IGBT transistors. If the rearmost amp fried, add at least four more components and a lot of work carving out burned board and wiring around the blown circuit traces.
May 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Wiring of a burns sonic guitar 1961
I have a Burns Sonic 1962. It has a complex "quirky" parallel/series wiring circuit with 3 pots, 2 switches and 2 Burns Tri-Sonic pickups. 2b4fdbd.jpg
Mar 01, 2010 | Epiphone Les Paul Studio Electric Guitar
Peavey signiture EX wiring
if the signature ex has any special plugs then the actuall diagram for that guitar is needed. but if it uses the standard two or three potential meter ( volume knobs and tone knobs or (pots) ) with a pick up selector and an input. then you can use any guitar wiring diagram and i think you can find that on web. wiring the pick up should be shown in the diagram with the pick up selector.
Feb 23, 2009 | Peavey Music
Epiphone Les Paul Studio Electric Guitar Logo
Top Epiphone Music Experts
Robert Graf
Vito Vacirca Jr.
dave nyman
Level 1 Expert
Are you an Epiphone Music Expert? Answer questions, earn points and help others
