Question about Zebra GK420D Direct Thermal Label Printer
GK420D horizontal alignment too far left - Zebra GK420D Direct Thermal Label Printer
Is there a sleep setting on a gk420d after being idle for 5 mins
There is no sleep mode on the Zebra G series.
Contact www.lancerlabels.co.uk for expert help with Zebra thermal Printers
Feb 12, 2015 | Zebra GK420D Direct Thermal Label Printer
Zebra gk420d not printing shipping labels properly on ebay
You have to go to printer drivers on your Operative system, then open printer properties, general tab, you will be able to check the horizontal/vertical setting of the label there.
Mar 02, 2014 | Zebra Gk420d Direct Thermal Printer -...
Zebra GK420d Driver for my Mac
There is a commercial driver for Zebra printers on Mac OSX, works perfectly with the GK420d printer even from courier Websites and Ebay shipping. You do have to pay for it but it works.
Details are here:
Mac Thermal Driver For OSX Print Directly To Label Printers On OSX
Hope this helps people find what they need.
Jun 11, 2012 | Zebra LP 2844 Thermal Printer
My zebra gk420d printer stops printing.
You can ask a printer Maintenance Technician to solve the problem for you.
Feb 23, 2012 | Zebra GK420D Direct Thermal Label Printer
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
Have black line on right side of screen and cant see all of icon on left side of screen
What type of screen do you have? If it is a CRT (rather than a flat panel) it is probably due to the screen alignment.
Go into the menus on the actual monitor and look for something called Horizontal Alignment (or similar). You should be able to move the whole picture left and right. You may need to play with some of the other settings (e.g. Horizontal Size) to get it just right.
Matt.
Apr 15, 2008 | Computers & Internet
Open Questions:
See all Zebra GK420D Direct Thermal Label Printer Questions
Zebra GK420D Direct Thermal Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
