Question about JVC AV-K29MX1U 29" TV
ELEKTA 21"led tv showing no signal display and no sound
I have an Elekta 58" LED Tv. I can hear the sound on the TV but i can't get audio sound when connected to my Home Theatre system
The TV sound output is either switched off, the wrong setting. The same might apply to the Home Theatre system.
Dec 07, 2016 | home Audio Players & Recorders
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
I am having sound issues with my 6-day old Elekta 32inch LED TV - it keeps cutting in and out. Sometimes comes on fine, then drops out completely,behave tried adjusting sound ... HELP!
Sounds like speaker fault. Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 20, 2015 | Televison & Video
Panasonic beat pump
Possibly, check error codes for problems:
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display. Note: Display only for "- -". (No transmitting signal, no receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
May 31, 2015 | Panasonic Heating & Cooling
Elekta lcd tv service centre in kerala
any body know any
Elekta lcd tv service centre in india
Mar 13, 2014 | Computers & Internet
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
Elekta 21 colur tv. I changed f.b.t, now tv is working but some time high voltage sparking between picture tube & fly cap. Why?
Clean the final anode area of the picture tube, using rectified spirit or medcal quality turpentine, and apply some insulating compound, and refix the anode cap. The insualting compound, in the form of greese [Red] can be bought from most of the electroncic spare part shops at your town. Never use standard greese ther. The insulating greese is of special type.
Apr 26, 2012 | Televison & Video
I have a 12.1" elekta
If you are connecting a Laptop, be sure to switch the signal delivery on the laptop - (usually hold the FN key and press F8 twice).
  1. Hold the FN key and press F8 twice
  2. If not laptop Check your display settings on the computer (right-click on desktop - properties), and detect display's
Cheers,
T
Mar 02, 2011 | Computers & Internet
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
JVC AV-K29MX1U 29" TV Logo
60 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
