Question about Polti Vaporetto 2400 Canister Steam Vacuum
HOSE LEAKING WHEN USING TOOLS OTHER OSE STUTTERING AND WON'T STEAM HAVE USED KALSTOP
On further inspection the hose that is leaking appears to have a big 2 cm short faill like its been pushed into itslef thats hwy its leaking its not connecting correctly and the other hose i think a spring may have gone on the trigger itself. as when press steam come out and then won't its like the button you press to swith it off is shyt off and no steam.
Posted on Nov 22, 2013
How do I switch from tools to flooe on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi Cherie! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Jun 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How do I switch from tools to floor on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Why no steam on polti 715 no steam
I had this problem, that is, my Polti 715 would not create an steam at all. It turned out that the boiler/steamer unit inside the Polti was badly corroded. So the only way to fix it was to replace the boiler/steamer unit inside. I had to send my Polti to an authorized repairer to have it fixed. The reason for the corrosion was that I did not follow the manufacturers instructions fo run the Kalstop solution through the machine every few months to stop calcification in the boiler.
May 03, 2014 | Polti AS700 Canister Steam Vacuum
Steamer
Try running a phial of Kalstop through the boiler to descale the boiler unit. Calicification in the boiler and on the controlling solenoid can cause the unit not to produce steam. My boiler unit was so corroded that I had to get the boiler container completly replaced.
Feb 02, 2014 | Polti AS700 Canister Steam Vacuum
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
k
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam leaking from screw cap. can i get a new one?
you dont need a new steam cap if steam is coming out of the top, that is supposed to happen when the hose is clogged, it would be very dangerous if that didnt happen, the amount of pressure that thing holds is unreal if you think your cap is leakin steam take a second look. if the cap is not physically damaged then it should be working fine, 9 times out of 10 your hose is clogged
Oct 27, 2009 | Tristar SB Steam Buggy Vacuum
Heating up but no steam coming out
Will be clogged up with limescale, you should use Kalstop to prevent this, it is a bio-degradable, non-toxic limescale remover-preventitive.
Sep 26, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
The boiler stoped working on my eco pro 3300
There is a high possibility that the boiler has build up of minerals and requires cleaning. I suggest using a product called KalStop to remove the calcium buildup that is cause by leaving water in the tank for long period of time.
Mar 23, 2009 | Polti Eco Pro 3000 Canister Steam Vacuum
Vaporetto 2400 no access to water tank
The threads have probably stuck together with limescale. Push down with reasonable force while turning the cap, like you would if you were trying to get in one of the childproof bottles. This should crack the limecale and allow you to take it off. Then descale the threads on the top and machine using kalstop or whatever you use.
Jan 16, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporettto 3000 Steam cleaner
I suggest using KalStop to remove the calcium and minerals built up in the machine. Polti has built the machines to stop working when there is too much calcium in the boiler to prevent further damage.
Aug 24, 2008 | Polti Eco Pro 3000 Canister Steam Vacuum
Polti Vaporetto 2400 Canister Steam Vacuum Logo
67 people viewed this question
Top Polti Vacuums Experts
cwradio73
Kolbrun...
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
