Question about Saws
Stihl ts 360 avs needs fuel and vent lines
Someone removed vent lines before giving to me. connections are 3/16" on one end and 1/8" on the other. is there a missing piece in the middle?
5 Suggested Answers
SOURCE: hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Posted on Aug 03, 2010
H2_Brad
  • 425 Answers
SOURCE: FUEL LINE FOR THE TS 500
You will need to contact a Stihl dealer. Here is a link to the site where you can locate a dealer near you.
Stihl dealers
Posted on Aug 24, 2012
H2_Brad
  • 425 Answers
SOURCE: stihl madel ts420 how to change air filter
There are 4 torx screws on the black back cover. Here is the owners manual. It is explained on page 33.
Stihl TS420 owners manual
Posted on Aug 25, 2012
  • 14 Answers
SOURCE: stihl ts 350 super cut saw died in the middle of cutting a brick
i am doing one right now (ts350). I had no spark. 2 problems there. I had to replace on/off switch do to dust making it malfunction. still no spark so I had to replace the Ign. module. got great spark now. It's not cheap either ($226.00 canadian) had to order it from a dealer. Now I have no fuel getting to the cylinder so I have more work ahead of me. I hope this helps if you only have a no spark problem. It's about a 6 on the skill level.
Posted on Sep 21, 2012
I have a stihl ts 410 that runs but after use it floods with fuel and then won't start till I have vented it
Sounds like a faulty fuel tank vent, creating a vacuum lock. Replace the vent
Feb 16, 2016 | Stihl Saws
Fuel lione and filter came off in the tank
This is a simple repair.
1. Drain tank save fuel can be used again
2.Purchase fuel line replacement kit Lowes -Home Depot
3.Kit needs to contain feed wire and gas hose.
4.Disassemble cover to reveal fuel line connection to carb.
5. Feed wire from kit into fuel tank through fuel line hole.
6. Install new hose over wire connecting end into hook at end of wire
7. Pull hose through tank up to the carburetor
8. Remove wire and connect filter and hose to carburetor
9. Replace gas into tank, Ck for leaks
Nov 15, 2015 | Stihl HT101 Pole pruner
Stihl 012 av fuel lines
The 2nd line might be a vapor return line back to the fuel tank? I've dealt more with repairing bigger saws more than smaller ones. You should go to a Stihl shop&take a look at chainsaws about the same size as yours&take off the air filter cover&look to see where the carburetor lines go.
Aug 01, 2014 | Stihl 011avt Brake Handle 009 010 011 012...
Bt 360 stihl
possibly a fueling issue, check fuel filter, tank vent and possibly replace carb diaphrams.
Feb 25, 2014 | Stihl 08s Ts 08 350 360 Bt 360 Clutch Hub...
Suzuki ts 125 not starting
Hi, Suzuki and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Suzuki TS Fuel Compression Spark Air Timing
1979 Suzuki TS125 No Start What Gives
DOWNLOAD Suzuki TS125 TS 125 1984 1987 Service Repair Workshop Manual... $15
Suzuki TS200R Service Manual FREE
OEM parts for Suzuki
Suzuki TS 125 1978
May 06, 2017 | Suzuki Motorcycles
My stihl 031AV chainsaw bogs down when pulling trottle
Ive had numerous similar faults with both stihl and husqvarna saws. all turned out to be leaking fuel tank vents. Im not sure if this model has a vented tank or not but it might be worth checking. Sounds like a fuel/air issue.
Nov 28, 2012 | Stihl 031av Manifold /intake Boot 032 030...
Stihl dealers
Jul 10, 2012 | Stihl Saws
2010 Vespa, tried starting and runs while just idling. However, when you try to give a little gas it quickly dies. I did Tue best I could checking the air filter, fuel filter, spark plug, etc. Stuff I...
Hi, Divecop3 these tubes and hoses are for venting and must remain clear of obstruction and connection at one end otherwise the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa My Et4 dies as soon as give it gas
Scooter dies when give it gas
May 23, 2017 | Vespa Motorcycles
My stihl demo saw ran out of gas an i filled it back up with the proper mixture an now it wont start
Remove plug and clean/replace. also check in the tank for a filter on the end of the fuel line.
Ground the plug of the body of the saw and stry to start to see if you are getting a nice healty spark. If you tank ran dry then you may have contaminated your plug.
Jun 20, 2010 | Stihl Ts 700 Cut Off Saw Model Name Plate...
Replacing the fuel vent hose on a Stihl chain saw
If it's the clear vent hose that connects to the tank on the left side, that's it. There is a brass plug inside the hose that meters outside air in the tank to regulate the pressure. The hose connects to the tank nipple, done.
Nov 19, 2009 | Garden
Saws Logo
51 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
