Question about Danfoss 077B7002 Refrigerator Thermostat
How to install Danfoss 077B7002 Refrigerator Thermostat
Programming the danfoss thermostat
You can download the instruction for your thermostat from the Danfoss site.
Dec 08, 2017 | Danfoss Garden
Even on lowest setting, drinks too cold, freezing at back, ice.
Thermostat needs replacing. Can`t find one online but I would guess a standard Danfoss would do it.
Mar 18, 2016 | Whynter Beverage Refrigerator
How do you wire a new thermostat. accidently chopped wires from my old Danfoss one while decorating. I now have a white wire, with 4 inside it hanging. Bought a Herstmann but wiring is confusing?
what ever u do make sure to turn off furnace power supply as u may well burn your furnace circuit board if you havent already. btw there is a fuse you may have to replace on the circuit board. now as far as wiring, its quite easy, look on your new thermostat, it has all the same lettrers.
w= white, r+red, g+green,c= common, b=blue blk=black, or=orange
then turn on furnace power, if nothing comes on look on the circuit board to repplace fuse, usualy 3 amps
Mar 03, 2016 | Heating & Cooling
Why is Hotpoint RLA64T Fridge freezing up after new thermostat fitted?
Make sure that the temp probe from the thermostat is located exactly where the old one was. If it had a plastic sleeve on the old one, the new one will need that sleeve. You shouldn't need to calibrate the control if it is the one specified for this model. If it was a generic replacement then possibly it could need some adjustment.
Aug 02, 2014 | Hotpoint Refrigerators
Can you replace a danfoss TP9 with a honeywell ST699
I believe the TP9 is a programmable thermostat.
While it appears the ST699 is a timer that connects to a thermostat.
So yes, they both control 230Volt boiler-and-pump. But there are differences.
Google search each item and include .pdf in search parameter to find product manual for each, and then compare wiring differences.
Nov 19, 2012 | Honeywell Hardware & Accessories
Our true freezer won't shut off. we purchased a new cold control and it didn't help either. Is there a schematic or instructions for installation ?
Do you have a GE Thermostat or a Danfoss. It is important because the Danfoss uses a Temperature Control Relay if this is the case the relay contacts maybe stuck closed.
Nov 20, 2010 | True 12 cu. ft. Commercial Freezer TWT-48F
Wire colours to numbers on thermostat
GOTO DANFOSS .COM AND THEY HAVE HOW TOS ON EVERYTHING WITH A CUSTOMER SERVICE CONTACT GOOD LUCK HOPE THIS HELPS.
Jan 22, 2010 | Heating & Cooling
Danfoss TP5 programming manual required
This is the full manual:
http://danfoss-randall.co.uk/PCMPDF/6218.pdf
Very well hidden away on the Danfoss website!
Oct 29, 2009 | Honeywell Electronic Programmable...
Danfoss thermostat control frozen at 20 degrees showing room temperature 25 degrees when room temperature not that hot
See the link on the Danfoss site.  This has helped me http://heating.consumers.danfoss.com/xxNewsx/5dbcb2f9-e888-4d2d-9761-7470786749c9_CNP1.html
Nov 07, 2008 | Heating & Cooling
Danfoss 077B7002 Refrigerator Thermostat Logo
43 people viewed this question
Top Danfoss Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Danfoss Heating and Cooling Expert? Answer questions, earn points and help others
