Question about Yamaha Music
DEC dh1su 24vdc relay
No sound anymore is this relay guilty ?
I have a Mackie 406M Powered Mixer. can't get sound out of it anymore. all the input level set lights stays on. any suggestions
That sounds like the amp board died. Mackie parts can be hard to source, and Mackie is really slow to ship, so I suggest taking it to a Mackie authorized service center. Here's a link-
Contact Support Mackie
May 18, 2016 | Mackie Music
Fender G-DEC junior won;t power up the lights don;t come on it has a thermal cutout on the 12VAC transformer it was open circuit i tried bypassing it with soldered jumper still does not power...
Try changing out the Pico fuse. Only 50cents from online West Florida Components. Buy a few. Mine went out twice. It is Item # F021. It is a .5amp (500 mA)fuse-green and looks like a resistor. Location on the circuit board is near the transformer and on back edge or board behind the 2 brown wires connecting to the board and to the side of the 4 diodes there. I left the bad fuse in place and soldered the new fuse to it's legs-a lot easier and does not damage the PCB.
Oct 03, 2011 | Fender G-DEC Junior Modeling Guitar...
I have a clavinova that doesn't make sound
Try the headphone jack... if there is sound there, then it is either the speaker amplifier or a loose cable. It would be rare for BOTH speakers to fail completely.
Aug 29, 2011 | Yamaha YDP223 Digital Piano
I bought my g-dec jr form ebay last summer and really like this little amp but this past winter I went to use it, it worked for 3 to 5 min and shut down, but the power light just blinked moderately. I...
This amp uses a TDA2050 chip that has thermal protection. It is also a small amp that is NOT capable of high sound levels. If *********** can't stand to be within 5 feet of this amp you are playing TOO LOUD for this amp and it will shut down until cooled off to protect the amplifier chip. This amp is intended for practice. It would be adequate for sensible listening level in a 10 foot by 10 foot room. If you need more sound you will have to get a bigger amp. I would suggest you get a sound meter and verify the sound level. DO NOT exceed 4 hours at 90 DB... I know a lot of deaf musicians that have lost their hearing and they are not much good anymore.
Jul 16, 2011 | Fender G-DEC Junior Modeling Guitar...
We have a Kimball Player upright,it has model C controls,, the relays appear to be sticking, where can I get replacement relays,, if I manually activate, the piano plays good
Find the coil voltage and whether it is AC or DC coil andd the contact configuration. The search for relays at Digikey,com, Mouser.com, and others.
DO NOT replace the relays UNLESS you can see that the contacts are bad and fail to close. If the relay fails to move, verify the coil is open with an ohmmeter since a bad driver transistor will fail to actuate the relays.
OFTEN you can fix a sticky relay. You may find contamination in the magnet area that keeps it from closing. Remove a relay and actuate it observing operation looking for the problem.
SOME relays are used to protect speakers if the power amps don't balance... one can damage the speakers in this case. Manually actuating those relays will result in a pop in the speakers although sound MAY come out.
Jan 22, 2011 | Music
The cooling fan on the behringer 500 doesn't work. The fan is good, but the 24Vdc isn't there.
The fan in this is throttled depending on three temperature sensors on heat sinks in the unit... Until the temp is up the voltage will be far less than 24 volts. Two sensors are on the power amp heat sink and another on one of the heatsinks with the IGBT's in the power supply. The fan will run slow and very quiet until unit warms.
Nov 28, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Music Logo
52 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
