I am trying to input numbers on a form but my cursor turns into a tiny hand prohibiting me from doing so. How do I change this?
    Sergeant:
  • 369 Answers
That says that either it is not in edit mode or its busy loading or that container is for Alphabets not for numbers.
Posted on Jul 12, 2014
I am trying to input numbers but my cursor turns into a little hand and I can't type in anything. How do I change this?
You need to explain what software you are using.
Check to see if you are in view mode or edit mode, and that your cursor is in an edit area.
If you are getting a hand, then you are in view mode, or in a spot that is not an editable area.
Nov 20, 2013 | Compaq Presario 5000 PC Desktop
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more: http://www.ehow.com/how_4840499_turn-hdmi-input-sharp-tv.html#ixzz2a6Xat0JU
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
Cursor jumping around while typing text
You wouldn't have some live insect in your keyboard have you? I've seen Microwaves do strange stuff when infested with some tiny insects BUT I doubt it's the case with your machine. I am trying to recall a Keyboard key that I sometimes accidentally press when trying to create a document using Word, etc which does the same or similar to what you've described. It pees me of as I don't know which button I hit, it is one of the main reasons I avoid Word, Outlook, etc. Please let us know if solved, cheers.
May 02, 2013 | Computers & Internet
I have a 37" vizio. I was switching input form tv
Press the input button and the set will turn on. Keep pressing the input button until the correct input is selected.
Nov 03, 2010 | Vizio VW37L 37 in. LCD HDTV
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
I have a hand instead of a arrow as a curser it is hard to check off email how do i change back to arrow
there is also a "feature" on the IE toolbar called "panning hand". Click that to turn your cursor back to the arrow or vertical bar when using IE to compose email. I think Alt + G toggles it too.
Dec 06, 2009 | Yahoo Mail
I am on windows XP. I have copied a PDF form on to my local disk. PDF document properties indicate that Filling of form fields is allowed yet I cannot fill the form fields. What do I have to do?
Try this first.
Look at your cursor. If it is a Hand, you have selected the hand tool. If not, go and select the Hand tool.
With the "Hand Tool" selected, go over one of the fields that you can type.
1. If the cursor remains as a "Hand", then the fields are NOT fillable. It can be printed, but NOT filled.
2. If the cursor changes from a "Hand" to a vertical line ("I"), -the one you see when you can type- then the problem is different. If this is the case post again and we can continue the search.
Sep 29, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
I have the code put it in still not working dont no how to put it in
NOTE: IF YOU TRIED UNSUCCESSFULLY TO ENTER YOUR CODE YOU MAY BE PROHIBITED FROM ANOTHER ATTEMPT FOR UP TO 24 HOURS. See below--section C
A. Input Security Code:
  1. Enter Standby: Press the [SRC] button. Select the "ALL OFF" display.
  2. Enter Menu Mode: Press the [MENU] button for at least 1 second. When "MENU" is displayed, "Security"/"SECURITY" is displayed.
  3. Enter Security Code mode: Press the [|<<] or [>>|] button for at least 1 second. When "ENTER" is displayed, "CODE" is displayed.
  4. Select the digits to enter: Press Press the [|<<] or [>>|] button.
  5. Select the Security Code numbers: Press the [FM] or [AM] button.
  6. Repeat steps 4 and 5, and complete the Security Code.
  7. Confirm the Security Code: Press [>>|] button for at least 3 seconds. When "RE-ENTER" is displayed, "CODE" is displayed.
  8. Do the step 4 through 7 step operation, and reenter the security code. "Approved is displayed and the Security Function activates. However, if you enter a code different from your security code you have to start over from Step 4.
B. After Pressing the Reset button or when removed from power source.
  1. Turn the power ON.
  2. Do the step 4 through 7 operation, and reenter the security code. "APPROVED" is displayed.
C. If an incorrect code is input, "WAITING" is displayed and the input prohibited time shown below is generated. After the input prohibited times lapses, "CODE" is displayed, and input can be done.
1 Time = 0 minutes
2 Times = 5 minutes
3 Times = 1 hour
4 Times = 24 hours
Here's a link to the manual:
http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KDC-MV6521~6021~5021%20(EN).pdf
Apr 23, 2009 | Kenwood KDC-5021 CD Player
Need the ability to "tab" from field to field on right of kybd
When you press ENTER to finish working in a cell, Microsoft Excel moves the cursor one cell down by default. However, you can select the direction in which you want the cursor to move.
  1. On the Tools menu, click Options.
  2. On the Edit tab, do one of the following:
    • To change the direction in which the cursor moves, select the Move selection after Enter check box, and then select a direction in the Direction box.
    • To keep the cursor in the current cell, clear the Move selection after Enter check box.
Note When a range or set of ranges is selected, pressing ENTER moves the cursor within the range or set or ranges only.
Jan 22, 2009 | Logitech Marble Mouse Trackball
Child Lock is on and I am second owner of tv with no code
This function will block out the picture and sound of the selected channel or video input.
It can also be used to keep the TV from being viewed for a scheduled time period that you set.
The code to enter the Locks feature is a four digit secret code number. The factory preset code is 0000.
Use the number buttons to select access code.
Use CURSOR G or H to highlight function and then press the SELECT button.
To change the access code number, select Change Access Code. Enter a new four digit key number you prefer.
Select CHANGE ACCESS CODE to change factory preset code (0000) to your preference.
When ENGAGE LOCK is selected, SET CHANNEL LOCK, SET INPUT LOCK, and SET FRONT PANEL LOCK can be set individually.
When SET CHANNEL LOCK is turned on, the picture and sound for the chosen channel will be blocked out.
When SET INPUT LOCK is turned on, the picture and sound for all video inputs and the picture and sound for channels 3, 4 will be
blocked out.
When FRONT PANEL LOCK is turned on, all buttons on the Front Panel will be deactivated, except the Power button.
When TV TIME LOCK is turned on (r TIME LOCK) you can set the BEGIN and END times (CURSOR E) and the TV
cannot be viewed during that time period (Set clock first). Use CURSOR G or H to highlight ONCE (TV will time out one time
only), DAILY (TV will time out every day), WEEKLY - SUN~WEEKLY - MON (TV will time out one time a week) or OFF (to disable
this function).
When MOVIE RATINGS is selected, you can block various types of movies and video tapes based on motion picture ratings. Picturein-
Picture will also be blocked automatically (see page 45).
When TV RATINGS is selected, various types of television programming based on a parental guide ratings will be blocked.
Picture-in-Picture will also be blocked automatically
If you forget your secret code, use the factory code 7777 to erase your key number. This will reset the secret code number back to the
factory preset 0000.
Press EXIT to quit the menu.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
