Zm 400 stays on BBLOCK S41A - Office Equipment & Supplies
I use ZM 400. Recently, When I print, usually Scratched stamp. I don't know why. Please help me. Thanks for your watching
There must be a piece of debris in there.
Pull out the roll and examine closely with flashlight and magnifier.
And try blowing it out with canned air.
Jan 21, 2015 | Zebra ZM400 Direct Thermal-Thermal...
My monitor doesnt work
try pluging another monitor in to see if it is a problem with monitor
Aug 05, 2012 | Samsung LS19A10NS/ZM SyncMaster S19A10N...
LCD Display "BBLOCK V23" ?
it;s not a problem, they come like that dy default.
Feb 10, 2011 | Zebra S4M Thermal Label Printer
Says paper is out says ribbon is out. Both are loaded properly. Says head is open. It's not. Turned off and on. Received error code bblock v23
I am having the same issue. Please help. Not having luck with this printer. I thought it was easier to print some labels.
Jun 23, 2010 | Zebra Thermal S4m Dt Zpl 203dpi Rs232/par...
Zebra Zm 400 Ribbon Out
Could you please be a little more specific? do you even use a black ink ribbon? If not the printer should be set for thermal direct in the front panel. If you do have the ribbon installed then power down the printer and hold down the pause and feed keys. While holding them down turn on the printer and count to 6 and let go of pause and feed.
May 19, 2010 | Zebra 105SL Thermal Label Printer
Hi, My name is Hakan and I'm having trouble with an ZM 400 label printer. My ploblem is that I get Out of Ribbon, Pause in Zebra status Monitor. What can be the problem?
If you are using a colored ribbon it might be too transparent for the ribbon sensor to read. Re-calibrate the ribbon sensor.
If you're using black ribbon and you're sure that it's loaded properly and the sensor isn't being blocked, then print a sensor profile and re-calibrate the sensors if necessary.
Mar 03, 2010 | Zebra 203DPI Printer
Zm-RSSC v2 under
Dear i have send website address of your Windows 7 Ultimate 64x OS and the beta driver for Zalman Tech ZM-RSSC External Sound System.
please follow the instructions and keeps download it.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=3124&Xlang=en_us&Xcntry=USA&source=XOG
Feb 16, 2010 | Zalman Tech ZM-RSSC External Sound System
My Zebra Zm 400 keeps saying Pause Error Condition paper out however it is set to Direct Thermal. How do I get it back to the ready state?
make sure that the maximum lenght for the label is set to something greater than the physical length of the label. I was having this issue with a 4x3 label. As soon as I increased the maximum lenght to 5 inches it worked.
Dec 29, 2009 | Zebra 105SL Thermal Label Printer
Zm 400 printing issues
check under the printer driver to make sure the right media is set
Mar 31, 2009 | Zebra Z4M Printer
There is error "bblock" on zebra s4m printer printer is not detecting with pc
BBlock is BOOT Block. The printer is not booting up the settings completely. Probably got corrupted. You will need to download the bootblock version for this printer & upload it via either USB or LPT1 port. You should contact Zebra so they can direct you to the proper Zebra site for the download & instructions. The process of the upload is no more that 15-20 minutes.
Zebra phone # is 847-913-2259 I think option 2 is tech support. be sure to have s# of printer & tell them you need to find the boot block & installation info for the S4M. Good luck.
Feb 07, 2009 | Zebra Z4Mplus Label Printer
60 people viewed this question
jasbo
jasbo
