Question about Imer Workman II 350 Diesel Towable MultiMixer
IMER 360 not turning over - Imer Workman II 350 Diesel Towable MultiMixer
I have used a oil undercoat over a water based pr imer and it is not drying. What is the problem?
if the paint is ok it should dry BUT YOU SHOULD NOT USE DIFFERENT PAINTS WITHOUT A BARRIER PAINT BETWEEN painting systems they are desiged to attach to each other
Nov 27, 2017 | Cars & Trucks
Rest light imer on sharp pg c45x
Turn on projector, press and hold the input, enter and undo buttons on
the projector then while still holding those three press the on button. Make sure you do this before the timer goes to 0% or it wont turn on again.
Apr 21, 2011 | Sharp Notevision PG-C45X Multimedia...
How can u tell if a capasitor needs replacing on a imer 250v saw?
If you have to provide an external force to get it started every time, it means the capacitor is not providing the starting current for the motor.
Mar 08, 2011 | Imer CombiCut 250VA 1000 Lite 10"...
What is the the thread direction to remove blade is frozen
the threads arent reversed,so left or downward will loosen the blade,i have the same saw,dont over tighten when installing the new 1
Feb 24, 2011 | Imer Tile Saw Combi 200va Portable Tile...
Saw will not cut straight and destroys blades 250
I had the same problem. If you are cutting porcelain tile, it will not cut straight. The motor isn't fast enough.
These saws are made for stone cutting.
Jun 07, 2010 | Imer Tile Saw Combi 200va Portable Tile...
My imer number 357952006477633 pl give me my personal license key number
hey if im not mistaken the imer mumber is for the simcard, im not familiar with the personal license key number just the p.u.k. no. and the puk no is given in a **** of paper together with your simcard.hope it helps.
Sep 28, 2009 | Nokia 6600
Unlock zone code
I managed to unlock my DVD player with a solution I found on videohelp.com. I quote the solution:
I made my new RDR-HX750 code free with this Remote Controll program on my old iPAQ:
http://rapidshare.com/files/12586334/RC1_825.rar
Just follow these steps:
Turn player to DVD mode and switch off player (standby) with NO DVD inserted
Press 1 on NoviiRemote
Press 2 on NoviiRemote
Press 3 on NoviiRemote
Press 4 on NoviiRemote
Press 5 on NoviiRemote
Player turns on
Player shows "T:imer OK" on the display and turns off
Turn player on again, after that you can verify your firmware setting:
1. System Menu
2. Settings
3. Audio output
4. Dolby output
5. Just mark "Dolby Digital"
6. Press Angle button
If successful your code region should be "14"
The first problem is to find an old PDA with infrared (Irda) since the newer models no longer use Infrared. The PDA also needs to have windows mobile. I managed to get hold of one via my dad.
I downloaded the program via the link above; after some trial and error, I managed to install the NoviiRemote program.
After installing boot up the Noviiremote progra. You have to select the "sony 0" codebase; don't worry, it's easy to find after you booted up the program on your PDA and it comes with the download. You will see a screen with 5 digits: 1 2 3 4 5.
After this, the instructions say:
press 1 2 3 4 5; the player turns on.
Instead of what the instructions say, when I did this, my player did NOT turn on. I turned it on manually, then continued with the procedure. I pressed 1 2 3 4 5 and the display indeed said: t:imer ok. I don't know if it is necessary to press the digits before turning the DVD player on, but hey, who cares, since eventually it worked.
After this I went on following the instructions: turn on the dvdplayer, press the system menu button on the remote, go to settings, go to audio output, go to dolby output and highlight/select/mark "dolby digital". Then I pressed the angle button as mentioned. You see a "secret" textbox where your region should be displayed as 14. I tried to play my region 1 DVDs and voila, to my own surprise it worked!
I don't know who made the codebase for the Noviiremote program, but I am very thankful. I hope this helps more people!
Mar 22, 2008 | Televison & Video
Imer Workman II 350 Diesel Towable MultiMixer Logo
Top Imer Masonry Tools Experts
ray gallant
Tom Chichester
Are you an Imer Masonry Tool Expert? Answer questions, earn points and help others
