Question about WMF Bistro 384000952 Espresso Machine
Wmf bistro no power
My bistro 8000 does not start no power
How to reinstall missing wmf graphics filter
SYMPTOMS
When you start any of the programs listed at the beginning of this article, you may receive one of the following error messages:
One or more components are missing or broken. WMF graphics filter is missing.
Wmf graphics filter is missing.
CAUSE
This behavior can occur if the Windows Metafile (WMF) graphics import filter is damaged or missing.
RESOLUTION
To resolve this issue, rename the Wmfimp32.flt file:
- Click Start, point to Find, and then click Files or Folders.
- In the Named field, type wmfimp32.flt.
- In the Look in box, click Local hard drives, and then click to select the Include Subfolders check box.
- Click Find Now.
- Right-click the Wmfimp32.flt file, and then click Rename.
- Type wmfimp32.old.
- Press ENTER.
- Close the Find: Files Named Wmfimp32.old dialog box.
- Reinstall the program.
I hope that this helps!
Apr 24, 2012 | Gateway GT5242E PC Desktop
The pressure does not build up and the valve does not rise
There are photos of the WMF handle here. Make sue it is installed correctly, and the handle is in the locking position
http://www.hippressurecooking.com/pressure-cooker-review-wmf-perfect-plus-rating/
Apr 02, 2012 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
I have a 3L 22cm wmf perfect cooker which leaks, can you help?
Make sure the gasket is in the right position, the handle is placed on correctly and the slide on the handle is in the locking position. Here are more details on how to use this pressure cooker.
Aug 24, 2011 | Wmf/Usa 2.5qt Stainless Steel Perfect Plus...
Can I get a copy of Chinese user manual for Perfect Pressure Cooker?
Here are all of the pressure cooker manuals for WMF pressure cookers:
http://www.hippressurecooking.com/category/manuals/wmf/
Aug 18, 2011 | Wmf/Usa 4.5qt Stainless Steel Perfect Plus...
I have used the mailing labels in Microsoft Greetings 2000 program for several years, saving them from year to year. I used them in May of 2010 but since then have wanted to use them and it gives the...
SYMPTOMS
When you start Microsoft Greetings 2000, you may receive one of the following error messages:
CAUSE
RESOLUTION
- Click Find Now.
- Press ENTER.
Sep 16, 2010 | Computers & Internet
Wmf graphics filter missing! what is a wmf graphic filter?
  1. Click Start, point to Find, and then click Files or Folders.
  2. In the Named field, type wmfimp32.flt.
  3. In the Look in box, click Local hard drives, and then click to select the Include Subfolders check box.
  4. Click Find Now.
  5. Right-click the Wmfimp32.flt file, and then click Rename.
  6. Type wmfimp32.old.
  7. Press ENTER.
  8. Close the Find: Files Named Wmfimp32.old dialog box.
  9. Reinstall the program.
Dec 31, 2008 | Computers & Internet
Heres the fix, and it works!!!!
SYMPTOMS
CAUSE
RESOLUTION
- Click Find Now.
- Press ENTER.
Nov 30, 2008 | HP Pavilion a735w (PL308AAR) PC Desktop
Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Aug 12, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
WMF Bistro 384000952 Espresso Machine Logo
35 people viewed this question
Top WMF Coffee Makers & Espresso Machines Experts
David Burbee
David Burbee
Frank Russell
Frank Russell
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a WMF Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
