Question about Kitchen Ranges
Fix Bulb Holder in Cooker Hood
In an attempt to replace the light bulb I have removed one of the light housings, and now it won't fit back flush into it's socket. How do I fix it back in place properly? I have managed to change the bulb as I now know you have to prise out the glass holder with a small screwdriver.
    Top Expert:
  • Kitchen Ranges Master
  • 12,223 Answers
Please see the video attached, and fix it. GOd bless you
Posted on Nov 20, 2013
4 Suggested Answers
SOURCE: Replace headlight bulb on 2001 330i
1) Pinch the socket connector to release the 2 pin connector
2) Turn the Gray mounting bracket 1/8 turn CCW –it will come loose
3) Replace bulb – don’t touch new bulb with hand
4) Insert Grey mounting bracket and lock with 1/8 turn
5) Re-connect 2 pin socket connector – it will click in
Posted on Jan 07, 2009
  • 43 Answers
SOURCE: Mercedes C Class w203 side light bulb
Hi rogergilliant,
Joe here, The best way to remove the side light bulb is to go threw threw the inside. Have to remove the under front fender lining. There is a clip to remove the housing, but the best way to not damage anything is to go from underneath.
Posted on Apr 02, 2009
RixsFixes
  • 2200 Answers
SOURCE: need to change the brake light bulb
With the velcro door open, you now have access to the tray that holds all of the tail light bulbs. There are two tabs on each side of the tray that secure it to the tail light. Carefully reach inside of the tail light and lightly squeeze on the outside of each tab, releasing the tray from the tail light. See pics.
Thanks for using Fixya and please do rate this answer.
Tabs highlighted in red.
Posted on Nov 03, 2009
How do you change a side light bulb
Need a bit more info about make and model of vehicle. In general there is normally access through the back of the sidelight fitting. There should be a bulb holder insert in the back of the fitting that turns and you can remove. Take the old bulb out and replace, push the insert back into the bulb fitting and twist to secure. Ensure the sidelights are switched off before attempting this , or you may short the contacts and blow a fuse.
Feb 05, 2016 | Cars & Trucks
How do I replace the passenger side headlight bulb on a 2008 Mitsubishi Colt and is it a difficult job?
Probably a quick and straightforward process:
Go to local parts store to get replacement bulb. If it is the type that fits into a holder, continue.........
- Open hood
- Look at back of bad headlight
- Wire will go to Back of light to bulb holder
- Twist holder counter clockwise to remove
- Pull out old bulb
- Insert new bulb
- Reverse rest of process.
Cheers
Oct 01, 2015 | Mitsubishi Cars & Trucks
Best (Broan) K260A - I tried to change the bulb as well....completely inaccessible to change with hands (bulb is set deeper in hood, not even flush) tried gloves, rubber jar opener but cannot get access to...
The lamp holder assembly snaps into a hole in the range hood with spring clips. To remove the light bulbs, you simply push and turn, like older, bayonet style automotive turn signal bulbs. It seems you have broken your lamp holder assembly. Just break the trim ring so it can be removed, or you can try to take it out reverse polish style by releasing the spring clips from the middle inwards. Once the trim ring is loose, you can extract the body of the lamp holder through the hole... the wires will be barely long enough to stick out the hole if you are lucky. If you are crafty, you may fashion a repair on the separated lamp socket assembly. If not, your replacement part number is SV16569. just call nutone-broan at 800-558-1711 and they will be glad to ship you a new lamp shell socket trim assembly.
25439092-xipalmoknr3fbjmp51kycajc-3-0.jpg Retail on that part is around $50.
http://cdn.appliancepartspros.com/images/product/cache/broan-light-fixture-assy-sv16569-ap5178165_01_l.jpg
Feb 16, 2015 | Cars & Trucks
How do you fit a drivers side indicator bulb on a 2001 renault kangoo ?
open the hood locate the rear of the indicator , the bulb holder will turn anticlockwise about a quarter turn then will come out , fit the new bulb , push and twist , reverse for refitting, job done
May 05, 2014 | 2003 Renault Kangoo
How to replace bulb in front bumper turn signal housing 1995 jag xj6
hello,
  • Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
  • Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
  • Remove the front turn signal light unit in the bumper to change the turn signal bulb. Push gently on the inside edge and insert a blade between the bumper and the lens at the outside edge. Compress the spring and remove the lens. Fit a new lamp by inserting it into the plug. The side marker light is changed using a similar process.
  • Open the trunk to replace the rear fog light, stop light, tail light, reversing light and turn signal light. Remove the rear light cover and turn the bulb holder fastener 90 degrees counter clockwise. Remove the expired bulb, fit a new one and replace the parts, turning the bulb holder clockwise.
  • Thanks..
    May 21, 2011 | 1995 Jaguar XJ6
    Need to replace a near side headlight on a Mitsubishi colt 2006. I've heard from a mate that I have to access the bulb holder through the wheel arch? Is this true? Could anyone advise me on how to go...
    there's an access panel in top/front of the front wheel arch, if it's the left bulb lock the wheels to the right, if it's the right bulb, lock the wheels to the left.
    there's two release catches on the arch panel, one to the top & one near the body of the car, release these then just slide off to reveal the back of the light housing. This has one clip at the bottom and two locating tabs at the top.
    (Opening the hood will give more light & helps when putting the inner light housing back on as you can feel if the top tabs are located back in.)
    The bulb/wires just pull out of the fitting, and then pull the bulb out of the wiring block.
    Replacement bulb just pushes into the wiring block, then just push back into the housing (the tab on the bulb locates at the top of the fitting).
    It's also worth checking if the fuse in the glove box has blown too.
    Dec 08, 2010 | 2006 Mitsubishi Colt
    How to change the headlight bulb
    Open the hood. Look at top corners of headlight assy, and you will notice two metal "L" shaped holders. Rotate these forward out of their plastic mounts. Pull both up and completely out. With a little side ways jiggling you can now remove the entire headlight assy. Turn the bulb holder clockwise to remove. Gently pry the holding clip to release bulb holder and bulb {they are one piece) from wiring connector. Install new bulb in reverse order. Tip: clean new bulb with rubbing alcohol before installing into headlight housing, because oil from fingers will greatly reduce bulb life. Also many auto part stores will install for free if you buy the bulb from them.
    Apr 19, 2010 | 2005 Chevrolet Tahoe
    How do you replace the drivers side headlight bulb on a 2004 New Beetle convertible?
    1. Remove headlight housing. A.Open Hood and pull the release lever at the back of the housing. The headlight housing slides in and out of the body in tracks. B.Pull out the headlight housing far enough to disconnect the electric connectors, then slide the housing completely out. 2. Remove the retaining clip to remove the upper (low beam) or lower (high beam) bulb from the holder from the back of the housing unit. Remove the old bulb(s). 3. Do not touch the bulb with your bare hands! Wear clean gloves or hold with a clean paper towel. Fingerprints on the bulb will cause the bulb to burn out or explode!. Insert the new bulb. 4. Replace the retaining clips and insert the housing back into the tracks and into the body. Plug the electric connectors in and insert the housing completely. 5. Reposition the release lever to the original position being careful not to break the plasic lever. 6. Check your lights for operation.
    Nov 01, 2009 | 2004 Volkswagen Passat
    How to change a 2008 vw beetle headlight bulbs
    open hood then remove plastic around required lamp then remove wire & bulb clip remove bulb then insert new one and replace clip put cover on again and your done easy.
    Aug 24, 2009 | 2000 Volkswagen Beetle
    Front sidelamp new bulb holder replacement
    Open hood.
    Look behind light fixture in engine side of opening.
    See little plastic doors.
    Open little doors.
    Disconnect wire to bulb.
    Unsnap the little wire snap holding bulb in place.
    Remove bulb.
    Put new bulb in.
    Plug back in wire...close little door, close hood.
    3 minutes, if that
    Dec 10, 2008 | Mercedes-Benz E320 Cars & Trucks
    Kitchen Ranges Logo
    158 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
