Question about LEC Refrigerators
Pe507 tried resetting the temperature and -- has appeared
Aquastat pops reset when reaching temp.
Aquastat cycling controls do not have a reset button. What you are looking at is a manual reset limit switch. That is a safety control set at the MAXIMUM allowable temperature for the boiler to attain. More than likely the actual cycling control is not cycling at the correct temperature allowing the overtemp condition. The cycling control will be very close in external appearance to the limit switch but it will not have the red reset button and it is wired in series with the limit control and will turn the boiler off and on automatically based on its setpoint.
Mar 12, 2015 | Heating & Cooling
Why did my frigidaire refrigerator digital temp display numbers just disappear after I tried to adjust them up? I tried resetting by pressing the on/off button to the left of the adjustment arrows-the...
Good Afternoon Friend,
I understand that the digital display, on your Frigidaire refrigerator, went out after trying to adjust the temperature. Without seeing the display, you will not be able to tell what the temperatures are set at, as well as if there is any trouble with the temperatures being hi, should that occur. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When power is restored, if the display is still not showing, I recommend contacting your local authorized technician. The technician will be able to diagnose your refrigerator and determine why the display has gone out. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Refrigerators
Hamilton Beach 40996Z kettle is displaying an "E1" error code
That appears to be a thermistor problem. The thermistor controls the temperature and is normally not user-replaceable. Call the 800 number for verification and possible replacement of the kettle.
Jan 22, 2014 | Hamilton Beach - 1.7L Kettle -...
Outside temperature sensor
The outside air temperature indicator's displayed temperature can be recalibrated. Press and hold the reset select button for 10 seconds . While you continue to hold the button, the display will scroll through temperature settings from +3 to -3. When the desired correction value appears on the display, release the button, and the recalibrated outside air temperature will be displayed. Each time a desired correction value is entered, it replaces the previous value. Give that a try mmkayyy:)
Sep 03, 2013 | 2007 Honda Accord Sedan
Croc only heats up to 230 degrees is there a way to reset it
CHANGE TEMPERATURE SETTING from CELSIUS to FAHRENHEIT
To Change the Temperature Setting from CELSIUS [230 Degrees] to FAHRENHEIT [450 Degrees]
If [230] appears on the display screen, then the temperature is set to Celsius. To change back to Fahrenheit:
1. Turn off your flat iron and unplug from electrical socket (wait for 10secs).
2. Then plug the iron back into the electrical socket.
3. Press & hold down the HIGH [?]button, then press ON/OFF button. An "F" will appear on the digital screen. Your device is now in Fahrenheit mode.
Jul 23, 2011 | Crocs Croc 2 Flat Iron Titanium Plates 1"
I have lost my manual for Nexxtech thermometer model6312030. I can't get it to read the outside temperature after I changed the batteries. How do I reset to make it read. Or better yet, how can I get a...
You must reset the outside unit every time you change a battery. To rest insert a paperclip into the small whole marked "reset". Temperatures should now appear on the inside or remote unit.
St. Bruno, Quebec
Nov 10, 2010 | Vacuums
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a...
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a compressor issue rather than thermostat? Thanks
Jun 21, 2010 | Honeywell Electronic Programmable...
Problem for Sharp AR-5320
The Fault fuzer. Possible faults of the block of the fastening the scene or in contact of the join or in signal of the controller of the direct current.
Address please in service Sharp
H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error
Oct 08, 2009 | Sharp AR-5320 Black and White Copier
Adjust temp level of the oven .. model 34ja-5tkxw
Press the bake key.
Adjust temperature to 550 degress.
Press the bake key again and hold it for 3 seconds.
The temperature +/- should appear.
You can then adjust temp +/- 35 degrees.
Mar 24, 2008 | Magic Chef CER3725AA Electric Kitchen...
Refrigerators Logo
52 people viewed this question
Top LEC Refrigerators Experts
gbob59
Vernon Taylor
Are you a LEC Refrigerator Expert? Answer questions, earn points and help others
