Question about Casio FX-55 Calculator
Calculators I want to remove the fixed decimal place capabilty. The "fix " key.
  • 3 more comments
  • yobanca Mar 02, 2008
    Well the key FIX is on the screen and I dont know how to remove it
  • Anonymous Apr 03, 2008
    i cannot remove the fix buttom from the screen and i dont know how to make it be back to normal
  • Anonymous Apr 18, 2008
    How do you fix the fix problem on the Casio fx-55 calculator?
  • Anonymous May 02, 2008
    how do I remove "fix"
  • curious17 Aug 19, 2008
    cant get rid of the "Fix" mode on the screen.can anyone help?
SOURCE:
SOURCE: decimals
This is an easy one and happens often. Simply depress the orange "f" key and then select how many decimal points you want on the numeric keys. For example, for two decimal places you would push "f" 2. I usually keep mine on 3, but you can take it from here.
Posted on Apr 25, 2008
SOURCE: hp 49g+
You can press "rightshift" then "->Num" (enter) to convert a fraction to a decimal. To set it permanently, press "->Num" while holding down rightshift. You can also set this in the settings menu (Mode key)
Posted on May 19, 2008
SOURCE: I am trying to get
You should press SHIFT then MODE (setup). Then press 2. Done! If you want to change it back, just do the same again, but press 1.
Posted on Sep 01, 2008
SOURCE: sharp el506d calculator has the decimal in the wrong place.
Try pressing the FSE button to switch between Fixed, Scientific, Engineering, and Normal displays. When in Fixed display, you can use <2ndF> < TAB > then enter a number from 0 to 9 to choose the number of decimal places in that display. To reset EVERYTHING to factory defaults: With the calculator off, press and hold these three keys: <2ndF> < ) > < ON/C > then release all three. The calculator will go through a series of tests (it takes a few seconds) and then be at its factory defaults. I have uploaded the manual for this calculator at www.theusermanualsite.com.
Posted on Dec 09, 2008
  • 3 Answers
SOURCE: need to program to fifth decimal place
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][5][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Posted on Jun 11, 2009
108.2135 round to the nearest tenth
is this about the answer to your question, or how to make your calculator display that way?
If the former, .21 is closer to 0.20 than to 0.30, so it's 108.2 (period)
if the latter, it'll depend on your calculator. There will likely be a key or menu item saying DISP for display, or FIX. For many calculators, then there is an option for Fixed, Scientific, or Engineering. Fixed will take a (usually) one digit input for how many decimal places after the decimal to display, (rounded). Scientific will do scientific notation, taking how many digits after the most significant digit. Engineering will be for how many digits after the decimal place, where there are one to three leading numbers before the decimal so that the scientific notation exponent is always a power of three (easier to match units like watts, milliwatts, kilowatts, etc, which often, at least for metric, go in jumps of three orders of magnitude.
Good Luck.
Nov 11, 2015 | Office Equipment & Supplies
Reduce the decimal places
Press the MODE key a certain number of times until you get FIX. Select it. You will be asked to specify the number of decimal places (enter a number between 0 and 9). You can also choose the normal mode. However, if the result is too small or too large, it will be displayed in scientific notation.
May 08, 2014 | Casio Scientific Calculator FX82
How do i take of fix on a ti15
[FIX] [0.001] rounds results to the nearest thousandth.
[FIX] [ . ] removes the fixed-decimal setting.
You must press [FIX] before a Place Value key each time you want to
change the number of places for rounding.
Nov 28, 2011 | Texas Instruments TI-15 Calculator
How do i set my calculator to 3 decimal places
Press the MODE key repeatedly until you get a screen reading "Fix Sci Norm". Select "Fix" and then 3 to select three decimal places.
Sep 28, 2011 | Casio FX-300MS Calculator
How do i turn off "fix"?
All results are displayed to the FIX setting until you clear the setting by
either pressing [2nd] [FIX] [.] or selecting F (Floating) on the decimal notation menu.
Resetting the calculator also clears the FIX setting.
· After pressing [2nd] [FIX]?, you can select the number of decimal places in two ways:
- Press to move to the number of decimal places you want, and then
press enter, or
- Press the number key that corresponds to the number of decimal places you want.
· FIX affects only the results, not the entry.
Nov 25, 2010 | Texas Instruments TI-34II Explorer Plus...
How do i change the number of decimal places on a F-502
Press 2ndF [FIX] and a digit for the number of digits to the right of the decimal point. [FIX] is on the ENG key next to the 2ndF key at the top left corner of the keyboard.
Nov 24, 2010 | Canon F-502 Calculator
The display shows comas and misplaced decimals instead of properly placed decimals. For example 4258.32 reads as 4.258,32. How do I fix this on the HP-12c calculator? Thanks
Press and hold the decimal point key then press and release the ON key to swap the radix marks between US and European modes.
Oct 17, 2010 | HP 12c Calculator
How do i change from whole numbers to decimal places?
Press the [MODE] key repeatedly until you reach a setup screen that shows FIX SCI NORM with 1 beneath Fix, 2 beneath SCI, and 3 beneath NORM.
Press [1] to select (FIX) and follow it by the number od decimal digits you want (2 or 3 seem about right).
Mar 02, 2010 | Casio FX-115MS Plus Calculator
When I try to divide numbers that would leave a remainder like 1 divided by 6 which should give me an answer like 0.16666666666 instead all it says for an answer is 1/6. it does say in the manual to input...
To convert from fractions to decimals, and from decimals to fractions use the [S<-->D] key. If you want your decimal results to have a fixed number of decimal places press [SHIFT][SETUP][6:Fix]. Screen shows Fix 0~9. Enter the number of decimal places exemple 3.
Dans ce cas 1/6 is displayes ase 0.167.
Hope it helps.
Sep 23, 2009 | Casio FX-115ES Scientific Calculator
Problem with Casio FX 260 Calculator
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Dec 03, 2008 | Casio FX-260 Calculator
Casio FX-55 Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
