Question about Samsung Refrigerators
Samsung SRS583DW Fridge / Freezer not freezing
I have a SRS583DW side by side fridge / Freezer. the fridge side works perfectly, had to replace the fan once but apart from that no problems. The freezer side digital temp is constantly flashing and is cool but not -19 deg. I had one of my HVAC mates replace the heating element to see if that was the problem, was OK for 1 day then started flashing again. I have tried differing temps, power freeze, disconnecting, emptying and defrosting to no avail. Please help! - Dale
  • Samsung Master
  • 16,026 Answers
The unit has a built in defrost cycle that is controlled by the main board. You need to replace that board.
Posted on Nov 21, 2013
Testimonial: "Thanx Brad! how hard is it to replace yourself?"
  • dale jones
    dale jones Nov 25, 2013
    Can anyone tell me where the motherboard is located on on the SRS583DW (to avoid pulling the whole fridge to pieces).
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
SOURCE: samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Posted on Sep 19, 2010
diodeic
  • 1622 Answers
SOURCE: I have a Samsung RS2555SW Side by Side Fridge.
Your fridge not working is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this help in solving the problem. Take care.....
Posted on Oct 03, 2010
  • 116 Answers
SOURCE: I have a stainless GE profile PSS26SGPASS side by
HI has the temp held steady at 28? And do you notice if the fan in running in the freezer if you open the door do you hear a fan running, if you do not, then the problem is a bad control board located in the rear of the refigerator behind an small access panel this control board runs about 175-200.00 to buy.
Sean
Posted on Mar 26, 2011
heatman101
  • 43501 Answers
SOURCE: Westinghouse Virtuoso BJ423T-R Fridge/Freezer Freezer ices
Sounds like a couple of different issues here....
First, the defrost element may checkout, but is it being turned on??? It would seem as though the controlboard/timer are bad and not bringing it on to defrost the coils...
However the coils maybe frosting up more then usual because it also seems as though either the unit is low on charge or the condenser coils are plugged up and the heat is not being disipated properly...
Check the condenser coils to make sure they are clean....if the unit still is having a hard time cooling then it is likely that you have a small leak in the refrigerant system and it will need to be found, repaired, and the system recharged...
Here are a couple of tips that I wrote that will give you more details about hese things...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator not Cooling or Fridge not Cooling
heatman101
Posted on Jun 24, 2011
Samsung SRS583DW fridge side not cooling
The freezer has all of the cooling coils and the refer side is cooled by a small door opening between the two of them (air moves from teh freezer tinto the refer).
Sometimes there is something blocking the opening between the two.
Here's a good site that covers teh problem in detail:
Jan 03, 2015 | Samsung Refrigerators
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Samasung RS2577Sl
It might be that your fridge went into something called 'demo mode' that shuts the compressor down so as not to waste electricity on the showroom floor. The freezer and fridge sides both start to warm up, but the temperatures shown on the outside of the door never change, so you don't know you have a problem until you open the fridge or freezer and find you have a melted mess. My Samsung is 7 years old and we run into this problem frequently when our power is on and off, like just recently with hurricane Ike. Per the Samsung website, the cure for 'demo mode' is to unplug the fridge for 1 minute then plug it back in. They also suggested pressing Power Freeze and Freezer Temp together for 8 seconds until you hear a chime to cancel demo mode. Good luck. I really dislike this machine.
Jun 29, 2008 | Samsung RS2578BB Side by Side Refrigerator
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
344 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
