How do i unlock my philips video vr805
I have a old video recorder its a philips vr805, the problem with it at moment is it needs to be unlock,can you help me please
WHAT SORT OF TV DO I NEED, SO THAT I CAN STILL RECORD/PLAY WITH MY VIDEO RECORDER?
One that has a scart socket at least.it is the RCA connectors that are usually missing off the newer sets.nearly all new are hdmi so if there are no scart sockets or RCA you will need to buy an RCA to hdmi convertor to use old equipment.....otherwise upgrade to a hard drive unit with DVD capability and transfer all you videos over.
Apr 22, 2015 | Televison & Video
Programming TV-channels on old Samsung VHS video recorder VB-520T
I tried another position of te range switches and scanned again and again and then I found the tv channels finally.
Mar 25, 2009 | Televison & Video
Philips DVDR5220H - Changing record settings
Page 80 in the manual explains how to make the recording compatible with other DVD players. Page 58 explains about what files can be copied to where. I don't think that you can change the DVD format. However you could use the RGB output to feed a video input card on a PC and then do what you want with it.
Feb 11, 2009 | Philips DVDR 3355 DVD Recorder
I have a philips dvdr70
From the Sky box, plug one SCART lead to your recorder and plug another to your TV. Then plug a SCART from the TV to the recorder.
You can then select the SCART connector for the sky box to record programs.
This will work after the digital switchover. The switchover is only for 'normal' tv signals from your tv aerial
Jan 12, 2009 | Philips DVDR70 DVD Recorder
I have 10 year old tv Phillips model ts3258c101.Yesterday I purchased a digital video disk player & video cassette recorder. It will play a dvd. I now have found that I cannot record a video cassette...
Check if your disc player is a twin tuner model which will allow you to do what you want. It might just need configuring properly. Otherwise there are devices on sale that will allow you to achieve your goal. Good luck.
Sep 26, 2008 | Philips Televison & Video
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Sep 09, 2008 | Philips Televison & Video
I have purchased an HDD & DVD Player/Recprder with digital tuner;
That wil depend actually if its supported by your old TV, since on the old televisions there are video 2 and video 1, NTSC/PAL options. whats the TV brand? did you contact philips regarding the compatibility with the TV?
May 31, 2008 | Televison & Video
UNKNOWn disc type
Me too - I've had a DVR3305/05 for just over a year and yesterday after using a lens cleaning disc it refuses to play anything !!! My advise is to stay away from Philips !!!
Nov 13, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
