Kenwood KA-994 Amplifiler no sound from rear speakers.
When I have my amp set on surround I no longer have sound from the rear suround speakers. Everything seems to be hooked up properly.
  • 4 Answers
SOUND FROM YOUR SURROUND SPEAKERS COMES BY BECAUSE OF PROCESSING THAT TAKES PLACE IN YOUR SURROUND CIRCUITS. IF THE SURROUND MODE IS ACTIVATED AND U GET NO EFFECT AND U SURE YOUR SURROND SPEAKERS ARE OPERATIONAL AND FULLY FUNCTIONAL. THEN THE PROBLEM LIES WITH YOUR SURROUND DECODING IN YOUR UNIT. REFER TO QUALIFIED SERVICING AGENTS.
Posted on Oct 09, 2007
SOURCE:
No suround sound from my pioneer vsxd510
You have to use the Audio Deck or something like that, a software that is provided with your sound drivers. I had VIA sound drivers & I was provided with VIA HDeck (or something like that) I used it to fill sound into the rear speakers without plugging any extra Jack (only the green one)
You can also do this, right click on the volume button on the bottom left corner. Click on Playback Devices > Speakers
click on the Configure button on the bottom left corner of the dialog.
Choose your audio configuration.
Stereo ( 2 Speakers)
Surround (more than 2 Speakers)
Hope this helps.
Jul 07, 2013 | Audio Players & Recorders
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
I have had the Kenwood VR-407 since 2001. I also have a Mitsubishi projection TV, attached to the receiver. When watching regular cable TV (u-verse), I can not get sound from the rear speakers. I am using...
Most TV stations you watch don't send a surround sound mix so you won't get anything in the back speakers. DVDs generally all have a surround mix which is why it sends to all speakers. What you are experiencing is normal, Bob.
Jan 04, 2011 | Kenwood VR-407 Receiver
I don't now what settings to use on my technics stereo system it has 5.1 surround sound. My prob is I don't now what levals to set the speakers at for best results in the book it says I should hear bullets...
switch off pro logic/switch on supper suround/press button twice it will say MOVE:/
switch on Supper suround EQ then Vertual Rear suround then Multi Rear suround then Seat Position.they should be lit GREEN exsept Vertual Rear & center focus.
Seat Position should flash when it does move the curser in the middle of the jog dial.......... i.e UP:DOWN :LEFT :RIGHT .let go & it will set itself. then switch on the Supper s woofer on the amp to MID.
I THINK L.O.L
Jun 10, 2009 | Technics SC-DV290 System
Buzzing on certain speakers (but not all)
do you have the problem in stereo mode (no suround) Try to disconnect rear speakers and see if you still have the buzzing if you do then disconnect center and check,using only the mains,process of elimination, check your polarity + - on speakers and check the wire.I would double check ALL connections even RCAs
Feb 01, 2009 | Yamaha HTR-5840 Receiver
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
BIG RED
Oct 30, 2007 | Yamaha DSP-A3090 7-Channel Amplifier
Surround Sound Speakers and AUX
You have the mode selector for the surround sound on the wrong switch setting. Look at the owners manual to see what setting you need for synthensized suround. Go to http://www.samsung.com if you need an owners manual. You will find it with a little bit of searching. Good Luck
Oct 08, 2006 | Samsung HT-P38 System
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
561 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
