Question about Toro Garden
My landlords toro riding mower starts fine but as soon as i touch the shifter to put it in gear it dies over and over..carb is clean and new gas with stabilizer
Also if i try to engage the blades it dies so all it will do is idle and thats it
    Scholar:
  • 46 Answers
There are several safety switches that prevent operation in case the rider falls off, etc. First check seat safety switch...the likely culprit. It must close ensuring a person is in the seat for movement or blade operation. Find a toro wiring diagram, or visually wire trace, or just inspect the proper operation of all safety switches. DO NOT BYPASS SAFETY SWITCHES, but ensure they are working properly for SAFE OPERATION.
Posted on Nov 20, 2013
  • 109 Answers
SOURCE: Mower starts but when the blade is engaged it stalls
Check the pulleys on the deck...one of them is jammed or rusted to the point that will not turn.
Posted on Apr 16, 2009
highspeedsan
  • 61 Answers
SOURCE: 6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Posted on Apr 26, 2009
  • 59 Answers
SOURCE: lawn mower ony runs at idle and dies after seconds
try holding the throttle open
Posted on Jun 26, 2009
harlan301
  • 205 Answers
SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Posted on Oct 13, 2009
  • 54 Answers
SOURCE: Hello,
It sounds like a fuel restriction, check the siphon tube. Also make sure your oil isn't over full.
Posted on Apr 28, 2010
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Toro riding mower motor dies when i put it in gear model56125
Sounds like a saftey switch playing up, i would start with the seat switch, you can check these with a continuity tester.
Apr 14, 2013 | Toro Garden
Toro 20624 mower runs rough
Remove float bowl from carb. Ensure gas flows with float hanging down. Ensure gas flow stops with float pushed up.. Remove float and meter needle. clean passage way were meter needle is inserted with a bread wrapper wire, with 1 in of plastic peeled off it, wire should be observed behind choke flap when fully inserted thru passage way. Replace float and meter needle. Clean float bowl. Observe float bowl screw, look to see if it has a hole thru it, if so clean with wire. Reinstall float bowl. Try to start.
Jun 17, 2012 | Toro Garden
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a problem starting my Toro Power Max 828 LE snow blower. It has fresh gas and a new spark plug. When you prime it it doesn't seem to be getting gas. It also has an electric start that is working...
Take a spray bottle and spray gas into the carb and see if it starts.If it starts you more than likely have a carb problem. first thing check and make sure gas is flowing to carb. Take the line off at the carb and see if gas flows through the line. If you have gas to the carb you will have to take carb off and clean it out and check to see if float is stuck closed.you might want to put a rebuild kit in it while it,s apart.
Dec 17, 2010 | Toro Garden
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
Aug 20, 2010 | Toro Lawn Mower With Toro Power Tools
Toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
202 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
