Question about Fujitsu SIEMENS Esprimo Mobile V5535 Speaker Set P4
La solution de sis191 undi ,pxe-2.1 sis191 pxe bootrom v1.3 use bev/bbs pxe-e61:media test failure ,check cable pxe-mof :exiting sis191pxe bootrom operating system not found
I want solution for this problem :la solution de sis191 undi ,pxe-2.1 sis191 pxe bootrom v1.3 use bev/bbs pxe-e61:media test failure ,check cable pxe-mof :exiting sis191pxe bootrom operating system not found
    New Friend:
No solution, just more info, not all movie channels.
Posted on Nov 20, 2013
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 10, 2012 | Dell Computers & Internet
Keeps saying boot failure along with Ethernet controller v1.06 and media failure, check cable
What you are describing is a hard drive issue, remove hardware and reseat it back in place sometimes this will restart the hard drive. If this fails have it tested.
Jun 04, 2012 | MSI Computers & Internet
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
No bootable device -- insert boot disk and press any key"
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
Nov 02, 2010 | Toshiba Qosmio G15 Notebook
When trying to reboot I'm getting this pxe-e61: media failure
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
Switching on my new hi grade laptop it read sis191 pxe bootroom v1.3 use bev/bbs pxe-e61 ; media test failure , check cable pxe-mof ; exiting sis191 pxe bootroom
Hi, You have to change the boot order in the system BIOS. i think it is set to try to boot from the network first before it tries to boot from the Hard Drive
You will have to change it to boot from hard drive first.
I'm not 100% but try it.
I hope I have helped you, if you need more help, let me know.
Regards - Anthony
Feb 08, 2010 | Computers & Internet
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
How do i repair my pc it gives a message that says Intel UNDI, PXE-2.0 (build 082) Copy Right (1997,1998,1999)Intel Corporation VIA Rhine II Fast Ethernet Adapter V2.43 (2005/12/15) PXE - E61: Media test...
Dear,
If you are using PC then make sure that Boot from PXE Rom is disable and boot from hard disk drive is enabled. Check your BIOS setting for configure it.
Regards,
Rakesh Kumar
Network Support Engineer
Apr 07, 2009 | Compaq Computers & Internet
Lap top will go any futher than entry screen...
This is a normal set of messages for a computer that is configured to attempt to boot off of a network server. Most home computers and laptops don't normally do this. If you never saw this before, booting from the network is probably the last try the computer makes before giving up. Basicially it is telling you that there is no valid boot device to start the computer from. It used to use your hard drive, but now it cannot because it has been disabled in the BIOS or the hard drive has died. You can check this by hitting the key to enter the BIOS Setup program (generally F10 or Del, it tells you when it is booting up) and making sure that the system does see your hard drive properly in the BIOS and ensuring that it is either first or second in the boot order.
Apr 07, 2009 | Packard Bell Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Fujitsu SIEMENS Esprimo Mobile V5535 Speaker Set P4 Logo
261 people viewed this question
Top Fujitsu Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fujitsu Audio Player and Recorder Expert? Answer questions, earn points and help others
